EBS - Multicomp  [schematic]
Re: EBS - Multicomp
Postby Sweetalk » 14 Dec 2009, 05:19
I'm looking the schematic of this pedal for reparing. A Friend broke the Active/Passive switch trying to open it to take some pictures, here are some!:
For this message the author Sweetalk has received thanks: 2
GodSaveMetal (25 Oct 2015, 15:05), modman (29 May 2015, 08:44)
Sweetalk
Has thanked: 23 times
Have thanks: 17 times
Re: EBS - Multicomp
Postby Sweetalk » 14 Dec 2009, 22:16
Sorry for the double post but, I fixed it... I tried to replace the switch and didn't work, replaced it by a jumper and didn't work also. The jumper was shorting a via hole. Now it's working. I hope you like the pictures, let me know if you need something from the pedal while I still got it!. :mrgreen:
Sweetalk
Re: EBS - Multicomp
Postby seele » 01 Aug 2010, 12:43
*bump* 8)
Any news about the schematic?
seele
Have thanks: 2 times
Re: EBS - Multicomp
Postby Sweetalk » 02 Aug 2010, 00:57
seele wrote:*bump* 8)
I don't have this anymore with me so I can't trace it. The pictures aren't so good to do this, sorry!!
Sweetalk
Re: EBS - Multicomp
Postby seele » 27 Jan 2011, 13:04
I borrowed this cool little pedal for a week and couldn't resist to open it.
The photos aren't the best but i managed to desolder the pots and write down some of the labels.
http://picasaweb.google.com/derseele/Multicomp?pli=1&gsessionid=gP7AeucPy0swTmgj7IrLog#5566829159094293106
Labels:
left upper side (under comp/limit pot)
TL064c
WT4-5n
The orange ones next to the switch
47516k542
v474t366
the black ones next to the switch
3fw-4n (2x)
right side under gain pot
jtp-51
rc4558 58m c92ng4
orange one 475-16k-542
near dc jack:
big one lt050sig
2x L4P
jtp51 (3x)
Hope this helps somehow...
seele
Re: EBS - Multicomp
Postby seele » 27 Jan 2011, 13:09
Nah, forgot to mention this is the version without True Bypass...
seele
Re: EBS - Multicomp
Postby supracat » 10 Feb 2011, 21:13
I have same problem with this switch in my Multicomp, so I wanted to ask you how did you fix it? Did you find a replacement for this switch?
Thx, :D
supracat
Re: EBS - Multicomp
Postby Sweetalk » 10 Feb 2011, 21:39
supracat wrote:Hi,
Thx, :D
In my local electronics store had the same switch. I just propper replaced it and worked like a charm.
Sweetalk
Re: EBS - Multicomp
Postby lolbou » 10 Feb 2011, 22:02
You can find such switches in Marshall amps too... I once had some from their french distributor (for cheap and delivered at my local guitar shop).
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 346 times
Have thanks: 234 times
Re: EBS - Multicomp
Postby seedseed » 21 Apr 2011, 11:53
This compressor is really good for bass has anyone managed to get a schematic from somewhere for it?
seedseed
Have thanks: 5 times
Re: EBS - Multicomp
Postby Vicus » 22 Apr 2011, 14:35
I have one of this with some problem, if someone have the schematic please send me a copy. Thaks.
Vicus
Re: EBS - Multicomp
Postby pedalgrinder » 19 Sep 2011, 05:12
hi everyone
where are we at with this one is there to much surface mount for a schematic to be put together. i can't seem to put enough detail together from those photos to have a crack would be nice to have one to have a go at. has anyone attempted a schematic yet???? This one would definately be a good one for the bass players as what i've read on the reviews its definately one of the better compressor out there. Can someone let me know what stage this thread is at??/
pedalgrinder
Has thanked: 201 times
Have thanks: 150 times
Re: EBS - Multicomp
Postby pedalgrinder » 23 Sep 2011, 03:28
don't everyone respond at once. :slap:
pedalgrinder
Re: EBS - Multicomp
Postby ryanuk » 23 Sep 2011, 11:33
pedalgrinder wrote:Can someone let me know what stage this thread is at??/
Pedalgrinder
You gotta have a little more patience. It doesn't look like anybody is currently running with drafting a schematic. Probably cause of the complexity of the boards (doubled sides, lots of SMD).
I think anyone undertaking to RE this one, would need the pedal in front of them for the best possible chance. There's just too many hidden tracks.
RyUK
ryanuk
Has thanked: 13 times
Have thanks: 27 times
Re: EBS - Multicomp
Postby Liquids » 23 Sep 2011, 17:04
pedalgrinder wrote:hi everyone
"Two in the hand is worth one in the bush"
The Carl Martin comp is pro-level using the best THAT chip available, one used in a few rack mounted compressors and should be more than adequate for bass, and there are schems/projects/etc here....
Feel free to buy one and take pictures yourself...DIY (Do It Youself) vs DIFM (Do It For Me), you decide...
Remember that the grass is always greener...where the cows 'fertilize' it :mrgreen:
Liquids
Has thanked: 15 times
Have thanks: 24 times
Re: EBS - Multicomp
Postby pedalgrinder » 24 Sep 2011, 04:40
yeah fair enough. I apologise for my impatience i just assumed with so much information there that someone was on it i was just trying to find out or see if i could help. I do like to give it a go and help rather than just sit back and let everyone else do the work. But those pictures would be almost impossible to trace a schematic. Cheers
pedalgrinder
EBS multicomp : problem
Postby farbiondriven » 28 Feb 2012, 18:33
Hi everybody, im here searching for some help, i really dont know what to do more :D
I do some repairing jobs on pedals, and someone gave me a broken ebs multicomp. It had a melted-down power-supply section, which i fixed, replacing a 100 R resistor, and removing the 100 uf filter capacitor.
The pedal worked fine. I gave it back to my customer, who broke it down again, supplying it with a 12v AC.
Now the pedal doesn't work, and it shows a 120 R resistance from Vcc and ground. The main problem of that device is that is ALL smd, very big trouble.
I REALLY need some suggestions :D
farbiondriven
Re: EBS multicomp : problem
Postby farbiondriven » 28 Feb 2012, 19:46
sorry, i havent read the rule about debugging. I've post it in the request section ! :)
farbiondriven
Re: EBS - Multicomp
Postby iv4nosky » 20 Dec 2012, 10:56
Hi , I have a death multicomp ebs. Its looks like that theres a resistance wich is burned and also a smd wich (107 p81) referecen is written over it. Does anyone any reference of a smd to replace it? I tried google but with no result during hours. Here is a pictures of the components:
iv4nosky
Re: EBS - Multicomp
Postby deltafred » 20 Dec 2012, 12:39
iv4nosky wrote:Hi , I have a death multicomp ebs. Its looks like that theres a resistance wich is burned and also a smd wich (107 p81) referecen is written over it. Does anyone any reference of a smd to replace it? I tried google but with no result during hours. Here is a pictures of the components:
Is this any use?
viewtopic.php?f=70&t=11143
deltafred
Has thanked: 357 times
Have thanks: 250 times
Users browsing this forum: No registered users and 10 guests
