Hi all,
I'm a woman from Holland and found this place in my search to build a CE-1 myself. I came to the conclusion that a mint condition second hand original is just way overpriced in my opinion. I refuse to pay that amount for it.
So i'd figure that I would build one myself... Really wanting that original sound of the CE-1!
Very ambitious of me btw, I have generic understanding of electrics and have augemented my knowledge but googling and youtubing the past 2 weeks.
But all-in-all I wouldn't call myself an expert.
Also I have learned a little about soldering when I replaced the pick-ups of my fender about 2 months ago. But also for the soldering part, I would like some advice on temperatures etc.
So, but I have been searching the internet for parts and so far have been able to find/buy the 4 IC's (the real deal ordered on ebay) and the resistors (local radio shack), some of the diodes (1N4007 instead of 1N4003, also local radio shack) and most of the capacitors (but the film-capacitors are in a plastic housing instead of in a raisin dip, againthese are from local radio shack).
So I am here with a few questions in regard of the deviation in parts I got at the local radio shack and that what is specified on the schematic.
1). First of, the transformer...
I have found a transformer that has exactly the output specified on the schematic, but am not entirely sure about it. Since transformers can be dangerous I was wondering if someone could help me verify that this is a proper replacement:
http://www.conrad.nl/ce/nl/product/505925/Platte-transformator-14-VA-Primair-230-VAC-Secundair-2-x-18-VAC-2-x-389-mA-14-VA-83267-Weiss-Elektrotechnik2). Then, I have received 4 1N4007's from the local radio shack when I asked for 1N4003's and found out on the internet the following:
- 1N4003 = Maximum Recurrent Peak Reverse Voltage: 200, Maximum RMS Voltage: 140, Maximum DC Blocking Voltage: 200
- 1N4007 = Maximum Recurrent Peak Reverse Voltage: 1000, Maximum RMS Voltage: 700, Maximum DC Blocking Voltage: 1000
Does anyone of you know if this will matter? Or should I order 4 x 1N4003 from china instead?
3). The 05Z15A diodes (on the back of the circuit)... I haven't been able to find these at all, not even a datasheet.
So I thought, I might replace it with another 15v zener diode:
http://www.haje.nl/product_info.php?products_id=32543Will these do?
Also I wonder if D15 is actually also the same 05Z15A diode, since is has the same symbol in the schematic and in the original schematic the is something written that looks similar to 05Z15A. Could someone confirm this? It would really bum me out if I would solder the wrong Diode on the board and my whole project would go up in flames.
4). The 2SC538F transistor is unfindable on the internet. However if I read the original schematic correctly it seems to me to say 2SC536F instead of 2SC538F. And the 2SC536F is easy to find (again from China, but who cares?
Would the 2SC536F work?
5). Q11, Q12 and Q13 remain unidentified on the schematic. Does anyone of you know what type these are?
And last but not least...
6). The TA7135P on the schematic seems to be listed as TA7136P on another schematic I have found. Does anyone know the difference between these IC's? Are they interchangable? Or something completely different all together...
Hope someone of you knows electronics better than I do...
Also... once I have acquired all these parts and have managed to create a printed circuit and want to start putting it together, what temperature should I set my soldering iron to in Celcius?
Thank you in advance for replying, you would really be helping a girl out.
BTW: I do not have an interest in one of the webshops of which I have posted links about. They are merely there because I need to check whether these parts will suffice or not.
