EHX - Small Stone ( LM13600 )  [schematic]
Postby borislavgajic » 13 Nov 2008, 11:09
enjoy :thumbsup
For this message the author borislavgajic has received thanks: 3
Andy2No (16 Jun 2018, 07:12), Dirk_Hendrik (02 Aug 2011, 21:16), modman (27 May 2015, 17:46)
borislavgajic
Have thanks: 248 times
Re: EHX-Small Stone-LM13600-guts
Postby Dirk_Hendrik » 13 Nov 2008, 11:43
Thanks!!
Has thanked: 250 times
Have thanks: 1008 times
Postby Alex Frias » 13 Nov 2008, 17:06
As the CA3094 and CA3080 are becoming scarce, this updated version with LM13600 and LM324 is very welcome.
Smaller Stone than ever!
Anybody could opinate about if it sound as cool as the old versions?
For this message the author Alex Frias has received thanks:
Dirk_Hendrik (02 Aug 2011, 21:17)
Alex Frias
Have thanks: 13 times
Postby borislavgajic » 13 Nov 2008, 17:11
My opinnion is that my ROSS phaser clone from TONEPAD sound better than this one.....
but it is only me :)
borislavgajic
Postby Alex Frias » 13 Nov 2008, 17:30
Mr Graemey, who even did some comparison, may you give us your impression?
He made this very interesting, as ever, vid:
http://www.youtube.com/watch?v=s1ySbg8R ... re=related
It's about old and new versions of Small Stone, but who knows if he knew the Nano's too?
Alex Frias
Postby Barcode » 13 Nov 2008, 19:21
borislavgajic wrote:enjoy :thumbsup
well guess who will be building this one :)
For this message the author Barcode has received thanks:
Barcode
Have thanks: 35 times
Re: EHX-Small Stone-LM13600-guts  [schematic]
Postby analogguru » 14 Nov 2008, 01:29
:hmmm: maybe...
:hmmm: maybe someone....
:hmmm: maybe someone who has downloaded the
EH Small Stone (LM13600) schematic
from uncleboko´s photobucket account :scratch:
For this message the author analogguru has received thanks: 3
Andy2No (16 Jun 2018, 07:13), Blitz Krieg (18 Jun 2015, 07:05), Dirk_Hendrik (02 Aug 2011, 21:17)
Have thanks: 116 times
Postby soulsonic » 15 Nov 2008, 04:34
Now, I need to open mine up and see which version it is... Does anyone know which circuit they used for the "Made in NYC" Reissue from about 6 years ago?
I will find out.
analogguru wrote: :hmmm: maybe someone who has downloaded the
:?: How do you find things in password protected folders? That link must have been posted somewhere, yes?
For this message the author soulsonic has received thanks:
Has thanked: 56 times
Have thanks: 265 times
Postby analogguru » 15 Nov 2008, 08:44
Yes, at the other forum - four years ago...
Postby destro » 17 Nov 2008, 05:21
and I am glad that it was. I think I got it from stephen giles posting it a ways back. I've got one and added a mix pot to it... thought about adapting the tonepad add on stages board to it.
For this message the author destro has received thanks:
destro
Re: EH - Small Stone ( LM13600 )
Postby whosyourdaddy » 27 Oct 2009, 22:21
Ok I see this topic is little bit out time, but I was wondering if someone have PCB and layout for this pedal.
Recently I've built ROPEZ and I'm not satisfied with the result.
did all mods and still ropez is to shallow with phasing. I'm not going to left couples of LM13700 to lay around.
I also found this if it's any help.
tnx
:cheers
For this message the author whosyourdaddy has received thanks:
whosyourdaddy
Have thanks: 7 times
Postby DimebuGG » 28 Oct 2009, 14:59
whosyourdaddy wrote:still ropez is to shallow with phasing
Are you kidding me?..
For this message the author DimebuGG has received thanks:
DimebuGG
Have thanks: 160 times
Postby graemey » 28 Oct 2009, 18:31
Alex Frias wrote:Mr Graemey, who even did some comparison, may you give us your impression?
Errr, better late than never :oops:
Just stumbled upon this thread:
Of the two SS's in the video, the old one just shades the newer one. Richer sound that rolls nicely around the sweep in a very harmonic way.
My old one still has the vol drop problem when engaged, anyone know how to lose it? It also has a strange problem when 1st powered up: I have to crank the speed knob up full to wake the effect up, then it stays fine until powered down by removing input jack.
I tried a friends Nano SS against my two and found it to be a bit thinner. Nice phaser but not the classic we all remember.
For this message the author graemey has received thanks:
graemey
Have thanks: 18 times
Postby whosyourdaddy » 28 Oct 2009, 21:30
Ok, so I've pretty much redrawn pcb from gut shots, but I'm not sure about these 3 points.
(I don't have patience to look at schematics now). So I need your opinion....
tnx
Dirk_Hendrik (02 Aug 2011, 21:18)
whosyourdaddy
Postby himister » 29 Oct 2009, 00:16
From the looks on the photo I could say I'm sure that point No.2 doesn't have connection between pad and triangular corner part.
No.1 looks like there is a connection between IC pads and No.3 pretty much sure that there shouldn't be connection since the tracks around these pads are separated. It's my logical conclusion. I hope somebody else would like to confirm it, but in case they don't, make them separated. :D They are very close so shouldn't be a problem to use a bit of solder to "jump" them. :wink:
Btw what have you used for drawing?
For this message the author himister has received thanks:
himister
Has thanked: 27 times
Have thanks: 26 times
Postby whosyourdaddy » 29 Oct 2009, 21:28
Ok so everything is ok then. It doesn't matter anyway this is just prototype (it's redrawn in GIMP :) ).
if this thing works maybe I will redraw layout in eagle...
tnx himister! [smilie=a_goodjob.gif]
whosyourdaddy
Postby himister » 30 Oct 2009, 00:14
Hey no worries. :wink: Glad to help.
I was kind of hoping that you didn't start pcb and layout drawing since I did it today and almost finished...need to finish component markings.
If you would like to post yours and contribute just go ahead and let me know, I will not post mine.
But if you think it's a to much fuss for you just say so... :D
Cheers. :thumbsup
himister
Postby whosyourdaddy » 30 Oct 2009, 01:00
Hey that's great news since I don't have nothing more to contribute. :roll:
Guess I'll wait for your layout then.
:thumbsup
whosyourdaddy
Postby himister » 30 Oct 2009, 02:14
Here we go...but please do some checking
I didn't mark some of the caps values 'cause schematic is really poor quality image and my eyes hurt from staring at it. :shock:
Some values I couldn't read at all. We need some brave soul to redraw that one. :lol:
Let me know if something is missing and freely do draw on the image so I could change it and export in pdf.
Cheers fellas. :wink:
Layout:
For this message the author himister has received thanks: 5
Andy2No (16 Jun 2018, 07:19), Blitz Krieg (15 Sep 2015, 07:30), Dirk_Hendrik (02 Aug 2011, 21:18), Manfred (14 Sep 2015, 21:21), sinner (27 Feb 2011, 23:43)
himister
Postby borislavgajic » 31 Oct 2009, 11:01
wow....you have my respect for doing sush great PCB........great :thumbsup :hug:
hvala puno Mihajlo
borislav
borislavgajic
Next
Users browsing this forum: Scruffie and 17 guests
