EHX - Small Stone ( LM13600 )  [schematic]
Re: EH - Small Stone ( LM13600 )
Postby borislavgajic » 31 Oct 2009, 11:46
http://www.pedalarea.com/images/eh_ss_usv3_02.jpg
http://www.pedalarea.com/images/eh_ss_usv3_03.jpg
this is from net, and perheps I can get that old one again to see.........analogguru-s schematic seem to be different from this PCB....speed pot is connected in different way..
boris
For this message the author borislavgajic has received thanks:
Haradax (31 Oct 2015, 13:12)
borislavgajic
Have thanks: 248 times
Postby orpheumlover » 31 Oct 2009, 12:12
This thread is great! Boris, you beat me to the punch on posting the http://www.pedalarea.com/small_stone.htm site. Good for you!
So, correct me if I am wrong. You guys are trying to figure out the schematic for the "version 3" not the "version 2. issue J", right? The V2 issue J has been done to death. Personally, I am a more of a fan of the V3 than of the V2, issue J. I have the green Russian Sovtek version, which is so different in circuitry and sound that Electro Harmonix should have just changed the name all together! I have a love/hate relationship with it.
Kepp going guys...you'll get it!
orpheumlover
Postby himister » 31 Oct 2009, 12:32
borislavgajic wrote:wow....you have my respect for doing sush great PCB........great :thumbsup :hug:
this is from net, and perhaps I can get that old one again to see.........analogguru-s schematic seem to be different from this PCB....speed pot is connected in different way..
borislav
Thanks bro. You're always welcome. :wink:
I've seen that that schematic differs from the pcb so I've been puzzled. :hmmm:
Who will solve this one?
I just need couple of markings to fill and it's done. So anyone willing to fill these gaps?
:D
himister
Has thanked: 27 times
Have thanks: 26 times
Postby whosyourdaddy » 31 Oct 2009, 18:17
Ok here are the caps values and also check some errors I've found.
:thumbsup
For this message the author whosyourdaddy has received thanks:
Andy2No (16 Jun 2018, 07:21)
whosyourdaddy
Have thanks: 7 times
Postby himister » 31 Oct 2009, 19:02
Well done man. :thumbsup Your layout looks ...well...very old style, almost original. You should just mark the corners so people could easier cut the board. I think we'll have a two boards for this one. Vintage style and modern style. :lol:
Thanks for the effort. I'll update mine very soon.
Cheers. :thumbsup
himister
Postby himister » 31 Oct 2009, 20:31
I hope this is the final one. :wink:
himister
Postby borislavgajic » 01 Nov 2009, 14:53
:hug: grrrreat great man!!!! :thumbsup
this should be added to completed projects list........
boris
borislavgajic
Postby himister » 01 Nov 2009, 17:51
borislavgajic wrote:this should be added to completed projects list........
Thanks. It should be, but not after some nice schematic redraw.
Here is pdf with pcb and layout but there's a empty space on the page for schematic. shame :cry:
Cheers :wink:
EHSmallStone_pcblay.pdf
himister
Postby Bernardduur » 01 Nov 2009, 20:32
Right now I have a Turkish Small Tone pedal in that is EXACTLY like this pedal!
It sounds awesome!
Bernardduur
Has thanked: 85 times
Have thanks: 475 times
Postby Bernardduur » 01 Nov 2009, 22:33
Bernardduur wrote:Right now I have a Turkish Small Tone pedal in that is EXACTLY like this pedal!
It sounds awesome!
Schematic
Bernardduur
Postby himister » 01 Nov 2009, 22:44
You are THE MAN of the Bernard-hour! :applause:
Cheers for this one. I already lost hope that someone will be eager enough and skilled to draw this one. I didn't have much time to draw myself and to be honest not even sure if the earlier posted schematic was accurate for this model.
I only wish you had post it couple of hours earlier so I could import it in pdf file.
Really good job and much oblige Mr.B :thumbsup
himister
Postby borislavgajic » 02 Nov 2009, 10:49
There is difference betveen schematic and layout....pot is wired differently....and some parts around it....! :thumbsup
so I guess I'll stick to PCB fabricated by himister :block:
boris
borislavgajic
Postby mocklie » 18 Mar 2010, 11:57
Are there anyone trying to verify this? I built today but it didn't phase-shift. Only the tone shift to treblly thing and color switch turn that deeper or shallower. Rate pot not work. I think the suspicious parts is a 3n3 capacitor above middle 13600. Seeing the gut shot it may be 47n. Any suggestions?
Thx. :roll:
mocklie
Postby whosyourdaddy » 18 Mar 2010, 12:34
Been there, done that, didn't work.
If it's any help, here is a layout by schematics:
whosyourdaddy
Postby jmwreck » 31 Aug 2010, 06:34
HELLO, are there any updates on this? :D
jmwreck
Have thanks: 6 times
Postby orpheumlover » 03 Sep 2010, 11:56
I am working on my 13600 Small Stone right now to change a couple out of spec caps. I was looking at your picture and noticed the cap in the upper left corner was labelled .22uF, which is the same as the schematic. I thought that may have been one of the problems with mine as mine had a 1uF in place there. It goes between the switch and clock (LM324). I changed my 1uF (which only measured .78uF) to the specified .22uf and then plugged it in. It was motor boatting like crazy and the rate pot did little to control the speed. Guess I'm going to change it back to a 1uF!
Also, the 22uf cap 1/3 of the way down on the right labelled on your picture is a 33uF on mine and on the schematic. When I first got mine that was the cap that was open and the circuit wasn't doing anything. So I found a spare one from a old stereo and popped it in there. It's out of spec (measures 30.1uF) and I suspect this is the one I have to change to depeen the cycle to make it work correctly. If a 22uF is in there, I figure that the phase cycle would be pretty shallow. Is that labelled correctly?
Lastly, we both have a 10uF electrolytic cap next to the 33uF cap 3/4 of the way down o the right. The schematic labels the 10uF as a non electrolytic. Apparently the schematic is wrong.
Thanks,
orpheumlover
orpheumlover
Postby GodSaveMetal » 14 Oct 2010, 00:35
I wana do this pedal; if I sustitute the LM23600 with the brother LM23700 it will be diferent????? :hmmm: and if will be a faviour please draw the conections of the pot, IN , OUT and +9V and ground!!! please don forget me!!!!!!!!!!!!!!!!!!!!!!! :hug:
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby borislavgajic » 27 Feb 2011, 22:12
somebody made this already???
Boris
borislavgajic
Postby GodSaveMetal » 28 Feb 2011, 19:31
GodSaveMetal wrote:I wana do this pedal; if I sustitute the LM13600 with the brother LM13700 it will be diferent????? :hmmm: and if will be a faviour please draw the conections of the pot, IN , OUT and +9V and ground!!! please don forget me!!!!!!!!!!!!!!!!!!!!!!! :hug:
Corrected my error of the IC´s, please it is posible the changes????
GodSaveMetal
Postby makrz » 02 Aug 2011, 11:45
Hello, my small stone works very well.
For this message the author makrz has received thanks:
Nocentelli (02 Aug 2011, 12:04)
makrz
Have thanks: 3 times
Users browsing this forum: d312a, Google Feedfetcher and 11 guests
