EHX - Small Stone ( LM13600 )  [schematic]
Re: EH - Small Stone ( LM13600 )
Postby makrz » 02 Aug 2011, 12:11
small correction
For this message the author makrz has received thanks:
yiyorebel (18 Dec 2014, 13:43)
makrz
Have thanks: 3 times
Postby GodSaveMetal » 02 Aug 2011, 21:25
makrz wrote:Hello, my small stone works very well.
You have your archive of this draw in SPRINT LAYOUT??? please you would post it???? thanks a lot!!! you have the external wirings of this??? please you would also post it?? thanks a lot for your hard work!! :applause: :applause:
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby makrz » 03 Aug 2011, 10:48
jstbrowsin (03 Aug 2011, 11:40)
makrz
Postby DrNomis » 03 Aug 2011, 11:52
Well, seeing that I'm a fan of Jean Michelle Jare's music, and knowing that he uses an EH Small Stone to get the phasing-effect on his albums "Oxygene" and "Equinoxe", I've just gotta build me one of these..... :thumbsup
Has thanked: 123 times
Have thanks: 386 times
Postby DrNomis » 03 Aug 2011, 11:55
Damn, that should have been "Jean Michelle Jarre", there was no edit button so I couldn't edit my last post, so I had to post my corrections.... :slap:
Postby mictester » 03 Aug 2011, 15:34
DrNomis wrote:Well, seeing that I'm a fan of Jean Michelle Jarre's music, and knowing that he uses an EH Small Stone to get the phasing-effect on his albums "Oxygene" and "Equinoxe", I've just gotta build me one of these..... :thumbsup
You'll find (as he did) that the phaser is a bit noisy, and introduces some distortion of its own. It's OK for guitar, but not really suitable for keyboards. JMJ used a Doepfer phaser on the early stage rig I saw, and then he went entirely digital by about the time of the third album.
mictester
Has thanked: 32 times
Have thanks: 788 times
Postby DrNomis » 03 Aug 2011, 16:53
That's something I didn't know, I just assumed that he used an EH Small Stone.... :shock:
Postby GodSaveMetal » 04 Aug 2011, 00:44
Thanks makrz; I see that it is a good work!!!!!!!!!! :applause: :applause:
GodSaveMetal
Postby Basoni » 28 Sep 2011, 14:13
You can post again? thanks!!!
Basoni
Postby gena_p1 » 02 Oct 2011, 20:59
from archives...
For this message the author gena_p1 has received thanks:
yiyorebel (18 Dec 2014, 13:40)
gena_p1
Has thanked: 27 times
Have thanks: 19 times
Postby gena_p1 » 02 Oct 2011, 23:28
Sry guys, I attached the same archive twice, and have no "edit massage" button.
gena_p1
Postby GodSaveMetal » 03 Oct 2011, 05:44
gena_p1 wrote:from archives...
Yeah great and thanks; please tell me if a sustitution for the LM13600 would be LM13700 with no changes??? :hmmm: or what I will chanche? :roll: cuz in my country it unabaliable the LM13600 but I found the LM13700; thanks for your interest and work!!! :applause:
GodSaveMetal
Postby mictester » 03 Oct 2011, 05:59
Yeah great and thanks; please tell me if a substitution for the LM13600 would be LM13700 with no changes??? :hmmm: or what I will chanche? :roll: cuz in my country it unabaliable the LM13600 but I found the LM13700; thanks for your interest and work!!! :applause:
That's fine - the 13700 is a direct replacement for a 13600. You won't need to make any circuit changes at all.
mictester
Postby GodSaveMetal » 03 Oct 2011, 08:22
OK thanks a lot !!!!!!!!!!! :applause:
GodSaveMetal
Postby Basoni » 03 Oct 2011, 16:16
The very EH uses the LM 13700 (SMD) on the Nano Small Stone!!!
Basoni
Postby theehman » 03 Oct 2011, 18:39
Basoni wrote:The very EH uses the LM 13700 (SMD) on the Nano Small Stone!!!
Didn't know they were doing that circuit. They asked me for a copy of the LM13600 Small Stone schematic a couple of years ago.
Ron Neely II
fx schematics and repairs
theehman
Has thanked: 81 times
Have thanks: 85 times
Postby yiyorebel » 10 Sep 2013, 16:35
Hello .... anyone can help me .... I need to know what the in, out , 9v , ground , and connecting the brightness switch ..... thank you very much . regards
yiyorebel
Has thanked: 15 times
Postby yiyorebel » 17 Dec 2014, 20:00
Hello , sorry for opening a mean old theme , I tell them , finish my small stone , I did work and it sounds incredible , the problem that after disconnecting it to put it in its box , stopped working , that did not happen , does not pass signal guitar when I touch with my hand 68nF capacitor upper ranges , the truth is that not be done. Any help thank you.
PD . excuse the English , use google translator.
regards
yiyorebel
Re: EHX - Small Stone ( LM13600 )
Postby minnow » 10 Jun 2015, 13:27
Hello everyone. Yet another revival of an old (and possibly uninteresting) thread.
I was comparing the Sprint layout by makrz which was re-upped by gena_p1 against the schematic (uncleboko / analogguru): http://freestompboxes.org/viewtopic.php?f=1&t=3567&hilit=13600#p38758
I noticed four differences. I have highlighted them in the attachment:
1. 1K8 on layout vs 1K on schematic
2. 100 on layout vs 100K on schematic
3. 33uF capacitor polarity swapped in layout
4. 47nF cap connects LM324 pins 1 & 4 on layout vs pins 5 & 7 on schematic (this is too heavyweight for me)
Looking at the LM324 datasheet, #4 (47nF cap connection) gets too complicated for me:
Should corrections be made on the PCB to match the schematic?
If the 47nF is not critical, could it be left out altogether?
Regarding 33uF polarized caps - could 47uFs be used instead?
Also, could anyone please slap me and tell me I should attempt a Tonepad Ross Phaser instead?
I supposed it is because this layout is big. And I could use a big enclosure I have without a purpose.
minnow
Has thanked: 26 times
Postby minnow » 18 Jun 2015, 01:29
Hi everyone. Some updates on this.
I have built this according to the layout (not the schematic values, refer to notes):
1. 1K8 on layout (vs 1K on schematic)
2. 100 on layout (vs 100K on schematic)
3. 33uF capacitor polarity (polarity follow schematic, not the layout)
4. 47nF cap connects LM324 pins 1 & 4 on layout (vs pins 5 & 7 on schematic)
It works! Great sounding phaser (coming from someone who dislike phaser effect).
However, there is a kind of "noise" that happens during the trebly end of the sweep (swirl). Like a flourescent lamp "eeeeeeek" noise.
When the sweep (swirl) is on the dark side of the moon, noise is not present / noticeable.
Hope my explanation is not too confusing.
This is noticeable in both switch positions. The position with deeper sweep has more noticeable "noise".
I have tried this effect without the guitar plugged in, meaning the pedal outputs directly to the amp, with a battery.
So ruled out my guitar pickups causing this problem.
I turned off my lights, turned off computer monitor (unplugged from mains) and tried the amp on two different power mains.
The amp is quiet with other pedals.
During my build, every component measured prior to soldering, and measured for contact after soldering.
STILL, probably a build error from my side.
But any help / clue on what to look out for will be great.
Could it be switch wiring error?
One more thing, when I unplug the guitar cable to the pedal, one switch position howls and squeals. Plug in again and it's gone.
I hope anyone else who has built it or anyone working on this can chime in and get this project in FSB going.
As always, thanks everyone!
For this message the author minnow has received thanks:
Blitz Krieg (15 Sep 2015, 07:28)
minnow
Users browsing this forum: box231, chino2, Cigano23, jefouc, oblivions, zamguitar and 18 guests
