DOD - FX30 Noise Gate  [schematic]
Postby andregarcia57 » 10 Dec 2008, 12:07
look.
andregarcia57
Have thanks: 87 times
Re: dod fx30 - noise gate
Postby andregarcia57 » 10 Dec 2008, 12:10
layout
andregarcia57
Postby earthtonesaudio » 10 Dec 2008, 13:53
Nice work, thanks for sharing! :)
earthtonesaudio
Has thanked: 17 times
Have thanks: 109 times
Postby fish head » 10 Dec 2008, 21:29
Thanks! :applause:
Anyone used this pedal? Is it any good?
fish head
Re: Dod - FX30 ( Noise Gate )
Postby andregarcia57 » 12 Dec 2008, 17:17
PDF complete with PCB print!
andregarcia57
Postby andregarcia57 » 11 Dec 2010, 20:52
what is the different between the two?
Dod - FX30
Dod - FX230
andregarcia57
Postby soundclone » 22 Jun 2011, 01:08
i can find J113 in local store , can i replace with J201?
soundclone
Postby iq01221 » 28 Jun 2011, 05:19
soundclone wrote:i can find J113 in local store , can i replace with J201?
I want to know it two, someone? :mrgreen:
iq01221
Has thanked: 35 times
Have thanks: 10 times
Postby earthtonesaudio » 28 Jun 2011, 16:01
The pinout is the same but the characteristics are quite different. The J113 is much more suited to this job, but the J201 will still work to some extent. Bumping the supply voltage to 18V could make it usable with a J201.
earthtonesaudio
Postby soundclone » 29 Jun 2011, 01:44
earthtonesaudio wrote:The pinout is the same but the characteristics are quite different. The J113 is much more suited to this job, but the J201 will still work to some extent. Bumping the supply voltage to 18V could make it usable with a J201.
what is the best JFET fo replace it?
soundclone
Postby earthtonesaudio » 29 Jun 2011, 03:44
If you can't find a J113 a J201 is the next best choice, in my opinion. I'm not terribly familiar with many other JFETs... maybe somebody can suggest another with a low VGS(OFF).
earthtonesaudio
Postby soundclone » 29 Jun 2011, 11:22
earthtonesaudio wrote:If you can't find a J113 a J201 is the next best choice, in my opinion. I'm not terribly familiar with many other JFETs... maybe somebody can suggest another with a low VGS(OFF).
tanks...i will try soon.
soundclone
Postby marsens » 10 Aug 2011, 13:04
Replace it with MPF102.
marsens
Re: Dod - FX30 ( Noise Gate )  [schematic]
Postby modman » 31 Aug 2011, 18:40
I found this schematic... does it match the above docs?
Has thanked: 3192 times
Have thanks: 599 times
Postby marsens » 01 Sep 2011, 05:42
Yes, but this schematic include led indicator on for the gate (on/off).
marsens
Postby andregarcia57 » 07 Mar 2012, 14:26
someone could work with replacement J113?
TL022 may be replaced by TL072?
andregarcia57
Postby grrrunge » 07 Mar 2012, 15:30
In my last batch of 2n5457's from Tayda, i had about 40% with a VGS(OFF) in the 0,70V-0,79V range, and about 10% with a VGS(OFF) less than 0,20V. Only 3 or so from a batch of 100 had VGS(OFF) above 1V
I don't know if that's low enough?
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby elkulon » 11 Dec 2012, 16:41
Nobody answered...
What's the difference between DOD FX30 and DOD 230... Both of them are Noise Gates, we know, but... What's the difference between???
elkulon
Have thanks: 3 times
Postby eeviac » 11 Dec 2012, 16:52
elkulon wrote:Nobody answered...
According to this website, the FX30 is based on the 230. The FX30 was then succeeded by the FX30B Gate/Loop. Here is the official schematic for the 30B. I don't know anything else about the differences between them.
eeviac
Postby elkulon » 11 Dec 2012, 17:21
Thanx, dude!!!!!
We really thanx your info!!!
elkulon
Next
Users browsing this forum: Paladin and 11 guests
