Bartolini - NTMB Bass Preamp  [schematic]
Re: Bartolini - NTMB ( degooped )
Postby quaternotetriplet » 09 Jan 2010, 06:39
i'm interested on how you modded it.
will you please post the schem man. thanks
quaternotetriplet
Has thanked: 10 times
Have thanks: 4 times
Postby chicago_mike » 10 Jan 2010, 03:21
viewtopic.php?f=10&t=7139&start=60
I cant find the schema I did with the vari-mid already in the bartolini circuit, but here is at least the circuit. :)
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 283 times
Postby lietuvis » 24 Sep 2010, 15:33
Hey this is my tryout to create nmtb preamp pcb,its not that big.the inductors that I can see on net found on mouser is 150mH are quite big 12mm diameter and 16mm lenght.I use few jumpers(they not marked but can be easy spotted), all wiring goes thru holes on pcb and connects in closest posible points according schematic.pcb is done on diptrace free software.
lietuvis
Has thanked: 84 times
Have thanks: 58 times
Postby lietuvis » 11 Oct 2010, 20:53
Is there anybody who successfully built ntmb preamp? I have, but not completely satisfied, the midrange control+range switch is very much interacting with bass control, it seems that midrange is not actually hump or dip at the given frequency corner selection, ether the Q is very low so it effect the bass range.on schematic at the very bottom it says OFF resistance of push pul MID pot is 47K (two R soldered to the pot), anybody knows what it means and what resistors have to be connected to pot.any suggestions?
the pic shows the second board I am building but without inductors and pots attached to it, identical to one I've built (was thinking to put on both of my basses)
p.s that picture was taken with laptop camera and it is reversed
lietuvis
Postby Jarno » 12 Oct 2010, 13:55
Don't recall the schematic. But I can imagine the Q of the mid-section, which uses the inductors, being dependent on the resistance of the inductors, the lower the resistors the sharper the Q will be.
Jarno
Have thanks: 8 times
Postby O.B.Y » 06 Feb 2011, 03:23
sorry.. can i ask? does it project use for guitar or for bass?
O.B.Y
Postby ezugaru » 23 Mar 2012, 18:12
Hi, does anyone built the bartolini ???
You are not dumb if you are a good person, is just that dumb people don't recognize the good things.
ezugaru
Has thanked: 44 times
Have thanks: 5 times
Re: Bartolini - NTMB Bass Preamp
Postby ioanniz » 21 Jun 2018, 15:16
well guys i finished mine from the vero, but now i'm a little stuck. the mids switch should be connected like the diagram i made ?
ioanniz
Postby X4t0 » 19 Jan 2019, 22:11
Hello my friends, i'm new in this forum, i tried to make the PCB version, i don't know if it works, i don't have any exp making PCB so this is my first PCB in my life :D , i'll be sharing the results and if it works and going to share the final PCB
X4t0
Previous
Users browsing this forum: No registered users and 10 guests
