DOD - FX13 Gonkulator  [schematic]
Postby Skarrgus » 15 Jan 2009, 04:55
If anyone wants this, here it is... Factory schem, so unsure of any errors.
For this message the author Skarrgus has received thanks: 3
Duckman (13 Jul 2015, 00:14), Manfred (18 May 2017, 08:07), modman (04 May 2015, 23:51)
Skarrgus
Have thanks: 15 times
Re: DOD FX13 Gonkulator
Postby soulsonic » 15 Jan 2009, 05:48
Thanks! I'd totally forgotten about that one!
Has thanked: 56 times
Have thanks: 265 times
Postby Skarrgus » 15 Jan 2009, 06:08
soulsonic wrote:Thanks! I'd totally forgotten about that one!
No problem... I actually forget what it sounds like. It's been almost 6 years since I actually played one. The part I'm interested in is the ring-mod. I'm thinking of putting a Punkifier circuit in place of the Grunge.
I can't remember, but I do recall there being a mod that enabled you to change the frequency of the carrier signal.
Skarrgus
Re: DOD - FX13 ( Gonkulator )
Postby krellmusician » 17 Oct 2009, 05:37
I modded one of mine (I have two; left the other stock) so that the distortion level control now controls the ring modulator frequency. I also added three toggle switches, one to toggle the distortion on and off (I picked a fixed resistor that produced an amount of distortion that I liked, and wired it in instead of the level control, with the toggle switching it in and out), one to set the ring modulator carrier signal range (switches a larger capacitor into the circuit to bring the oscillator into the subaudio range), and one to switch the internal oscillator feed between the triangle wave (stock) and the square wave (for a choppy tremelo at the subaudio settings; the square wave has a DC level shift that I haven't yet addressed, however, so that mod is less than successful). Space on the pedal was cramped but I managed to get everything in there. Ugly but somewhat more useful now; at least it passes the "Don Ellis Tears of Joy" test (I'm a trumpet player).
krellmusician
Postby borislavgajic » 17 Oct 2009, 09:01
krellmusician wrote:I modded one of mine (I have two; left the other stock) so that the distortion level control now controls the ring modulator frequency. I also added three toggle switches, one to toggle the distortion on and off (I picked a fixed resistor that produced an amount of distortion that I liked, and wired it in instead of the level control, with the toggle switching it in and out), one to set the ring modulator carrier signal range (switches a larger capacitor into the circuit to bring the oscillator into the subaudio range), and one to switch the internal oscillator feed between the triangle wave (stock) and the square wave (for a choppy tremelo at the subaudio settings; the square wave has a DC level shift that I haven't yet addressed, however, so that mod is less than successful). Space on the pedal was cramped but I managed to get everything in there. Ugly but somewhat more useful now; at least it passes the "Don Ellis Tears of Joy" test (I'm a trumpet player).
please can you post gut shot of original one? :) component and trace sides?
thanks
boris
borislavgajic
Has thanked: 137 times
Have thanks: 244 times
Postby Greg » 17 Oct 2009, 11:31
It sounds pretty bad.. :mrgreen:
Hard to forget..
Greg
Has thanked: 76 times
Have thanks: 194 times
Postby Antuan » 18 May 2017, 02:43
thanks
boris
Yes, please, the owners of this Gonkulator FX-13 need your habilities! And tank you so much!
Antuan
Users browsing this forum: aishabag23 and 7 guests
