DOD - FX22 Vibro Thang  [schematic]
Postby sikheazdraf » 01 May 2009, 11:35
hi everyone i was wondering if you guys can help me with my DOD fx22 Vibro Thang
i got it cheap and has issues with its bypass.. etc...
i think there's problems with the wirings and etc...
i hope that somebody would help me
and could be kind to post gut shots of the insides of the pedal
and also the schematic.. thanks!..
my vibro thang looks exactly like this:
sikheazdraf
Re: HELP!! DOD FX22 Vibro Thang GUTS & SCHEM
Postby puppiesonacid » 01 May 2009, 12:09
check out schematic heaven. I believe its there. if not pm me. I might have it in my dod folder.
puppiesonacid
Have thanks: 5 times
Postby modman » 01 May 2009, 12:18
schematic is not at schematicheaven, might be worth taking pictures of the pcb even if the wiring is messed with.
moved to request
Has thanked: 3147 times
Have thanks: 584 times
Postby Fuzzer » 01 May 2009, 17:19
puppiesonacid wrote:check out schematic heaven. I believe its there. if not pm me. I might have it in my dod folder.
If you have it why not post it?
Fuzzer
Have thanks: 19 times
Postby sikheazdraf » 02 May 2009, 09:30
modman wrote:schematic is not at schematicheaven, might be worth taking pictures of the pcb even if the wiring is messed with.
moved to request
yep i cant find it there :(
thanks...!
anyway here's the gut shot of my DOD and the wiring. i don't know what's wrong with it though :( :oops:
hope i could fix it with the help of you guys. thanks!
sikheazdraf
Postby puppiesonacid » 02 May 2009, 17:26
cuz I was at work when I posted :roll:
checked my folder... no such luck. don't know where I've seen it but I know its out there somewhere. If i come across it, I'll post it.
puppiesonacid
Postby lolbou » 02 May 2009, 23:04
The cut yellow wire seems weird to me, unless it's factory done...
Where's the switching system?
Is the switching like the boss pedals? Is it related to this yellow wire? Is Q4 and its neighbour part of the boos-like switching system?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 351 times
Have thanks: 240 times
Postby sikheazdraf » 03 May 2009, 00:14
lolbou wrote:The cut yellow wire seems weird to me, unless it's factory done...
i dont have any idea sir if the wire is factory done.
the switching system is found at the other side.
sorry but i dont really know a lot about electronics though :(
my friend's the one who'd help to work on this though. hehe
but we dont have an idea yet.. how.. hehe
sikheazdraf
Postby borislavgajic » 03 May 2009, 09:09
can you post some pictures of copper side ...
thanks
boris
borislavgajic
Has thanked: 140 times
Have thanks: 251 times
Postby sikheazdraf » 03 May 2009, 17:12
borislavgajic wrote:can you post some pictures of copper side ...
thanks
boris
here they are..
sikheazdraf
Postby sikheazdraf » 05 May 2009, 12:00
help! :cry:
sikheazdraf
Postby lolbou » 05 May 2009, 12:10
It looks like a FET switching (nothing mechanical here).
sikheazdraf wrote:has issues with its bypass.. etc...
Can you detail your issue? Always on? Always bypassed? LED always on, or changing its state, but with no effect on the sound??
lolbou
Postby Dirk_Hendrik » 05 May 2009, 17:45
lolbou wrote:It looks like a FET switching (nothing mechanical here).
Naturally, It's a DOD in "modern" style ;)
Is that a 4011 or a 4007 I see. Most DOD's have a 4007 vor their bypass switching/
My Q exsactly
Has thanked: 255 times
Have thanks: 1021 times
Postby Dirk_Hendrik » 05 May 2009, 17:47
4007.
Meaning that for the functioning of the bypass system about any DOD schematic that uses a 4007 applies.
Postby sikheazdraf » 05 May 2009, 17:53
here it is.. sorry for the bad quality..
http://tinypic.com/player.php?v=bjsi1&s=5
you could hear that when the pedal is chained theres a BIIIIG drop in volume!.. even without engaging it!..i think its the bypass?
and my humbucker equipped guitar sounded like a single coil guitar. :(
see the difference between when the DOD is chained and when the guitar is directly pluged in the amp.
thanks guys! :P
sikheazdraf
Postby sikheazdraf » 06 May 2009, 22:05
help! :|
sikheazdraf
Postby puppiesonacid » 06 May 2009, 23:22
impedence mismatching??? idk... thats wierd...
puppiesonacid
Postby Fuzzer » 09 May 2009, 01:54
I'd put the blame on the Dual Opamp, because that's the one affecting the signal when the effect is activated, as well as when it isn't.
This is a rough guess, of course, but Dirk Hendrik's appreciation is just spot on, you should dig some DOD schematics from that series to have a better approach.
Fuzzer
Postby sikheazdraf » 11 May 2009, 18:35
Fuzzer wrote:I'd put the blame on the Dual Opamp, because that's the one affecting the signal when the effect is activated, as well as when it isn't.
thanks sir.. what should i do with it sir?
sikheazdraf
Postby Fuzzer » 11 May 2009, 23:06
Take it out, put a socket in and then try another one.
Fuzzer
Next
Users browsing this forum: No registered users and 13 guests
