Boss - DI-1 Direct Box  [schematic]
Postby iloophao » 13 May 2009, 12:32
I use may DI box, I think this one is best!
For this message the author iloophao has received thanks: 3
azep24 (01 Apr 2018, 14:04), Duckman (02 Nov 2013, 21:00), rocklander (07 May 2012, 21:24)
iloophao
Have thanks: 7 times
Re: BOSS DI-1 gut shot
Postby Silent Fly » 13 May 2009, 12:54
Very interesting. Thanks iloophao.
Does anybody have the schematics?
Silent Fly
Has thanked: 20 times
Have thanks: 38 times
Postby RnFR » 13 May 2009, 12:59
looks neat. i've never tried this one before. what is that chip? i'm guessing it would not be easy to procure. when did this come out? early 80's?
Has thanked: 150 times
Have thanks: 174 times
Postby Silent Fly » 13 May 2009, 13:02
For this message the author Silent Fly has received thanks: 2
Silent Fly
Postby iloophao » 13 May 2009, 15:34
Duckman (02 Nov 2013, 21:00), modman (30 Apr 2015, 22:01), rocklander (07 May 2012, 21:24)
iloophao
Postby Dirk_Hendrik » 13 May 2009, 18:08
RnFR wrote: what is that chip?
The M5218(AL) is a pretty common SIL dual Opamp often found in Boss pedals as well as other orient developed stuff. Fisrt time I ran into em was whle reversing the CS3 but I've found em in Pioneer CD players as well. They're not rare, easily obtainable and share the same pinning as any standard dual opamp. It's just that we don't see em that much and therefore it scares us. Don't. In some cases the advantage of this SIL baby can be a large help.
Has thanked: 255 times
Have thanks: 1022 times
Postby RnFR » 13 May 2009, 23:58
yeah, i've seen the SILs in stuff like old tape recorders and the like. and yes, i do find them scary. :whappen: workin on that, though. i do wonder how this old piece stacks up against simpler DI designs. most are much more spartan.
Postby birgitay » 02 Nov 2013, 00:10
Zener Diode What is the value?
birgitay
Re: BOSS DI-1 gut shot  [schematic]
Postby apollomusicservice » 02 Nov 2013, 10:16
Zener has value 9.1V. Here's original schematic for Di-1. 8)
For this message the author apollomusicservice has received thanks: 8
birgitay (02 Nov 2013, 20:54), blackbunny (02 Nov 2013, 14:38), candidate (05 Nov 2013, 09:01), dai h. (03 Nov 2013, 04:26), Duckman (02 Nov 2013, 21:00), Fender3D (02 Nov 2013, 12:41), modman (30 Apr 2015, 22:01), x-tn (03 Nov 2013, 17:54)
apollomusicservice
Has thanked: 65 times
Have thanks: 773 times
Postby birgitay » 02 Nov 2013, 20:46
Thank you..
birgitay
Postby Mbas974 » 03 Nov 2013, 01:05
What it could be best replacement for the original Boss Op-amp chip ?
TL072 NE5532 JRC4558 LM833 etc....
Thanks.
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby dai h. » 03 Nov 2013, 04:27
re:5218, my understanding was that it's just a 4558 equivalent and nothing special
dai h.
Has thanked: 43 times
Have thanks: 11 times
Postby Mbas974 » 03 Nov 2013, 11:53
THANKS !
I suppose D5 is 1N4148 or similar.... it si connected to 9V, what is used for ?
Mbas974
Postby dai h. » 03 Nov 2013, 21:28
looks like it might be used to rectify phantom power (from a mixer input)
dai h.
Postby dai h. » 03 Nov 2013, 21:52
dai h. wrote:re:5218, my understanding was that it's just a 4558 equivalent and nothing special
edit:
to be a bit more clear, this is not to say that it sucks or is a bad choice for all applications. More to say that you probably don't need to find the same exact chip (which may cost you much more nowadays) and a ready available (inexpensive) 4558 will (probably) do.
dai h.
Re: Boss - DI-1 Direct Box
Postby Pollo » 03 Feb 2017, 01:31
Hi all,
Reviving this old thread to ask a question. I have this DI and I quite like it. Since I now had a look at the schematic I started to wonder whether it would be possible to get some extra gain out of it? The way it works not it attenuates the signal by roughly 2 dB. If I use it balanced I get an extra 6 dB of gain, so the nett gain is about 4 dB.
Could the op-amp circuit be modified to squeeze some more gain out of this box? Something like 20 dB would be perfect. In my admittedly naive thinking it may be as simple as replacing a couple of resistors. My understanding of electronics is far too little to figure this out by myself. Can anybody help me out? Even if it is only to tell me that my idea is not possible.
Thanks.
Pollo
Postby poiureza » 03 Feb 2017, 11:28
Thanks for reviving, I'm interested in this circuit as well.
Alas, I'm no good with balanced signals.
It seems easy to adjust the gain on one channel (change the 1/1 ratio of the R25/R26 resistor pair on IC1a)
However the other channel has IC1b wired as a pure buffer I think.
Btw I'm very intrigued by the auto power part. I need to breadboard that one !
poiureza
Has thanked: 17 times
Have thanks: 10 times
Postby Pollo » 03 Feb 2017, 13:36
You are raising the same kind of questions that I had. It puzzled me too how the second channel is wired. Wouldn't it make more sense if it was symmetrical? How about if I wire the second channel the same way as the first, with the resistor and capacitor in the feedback loop. Then I can experiment with the R26 resistor value to see what happens.
I looked at the auto power part too but frankly it's not that useful to me. I plan to always use it with phantom power.
That is another thing I would like to modify and that is probably pretty straightforward. I would like to have the phantom power on a separate socket. I think that is easy to do by taking R28 and R29 from the balanced out and rewiring them to an extra connector. Then I can remove the bipolars C12 and C13. Or should I replace them with different value capacitors? I can understand that they are there to block the phantom power but maybe they serve some other purpose as well?
Anyway, thanks for chiming in.
Pollo
Postby poiureza » 03 Feb 2017, 15:48
Lol, you have the same kind of answers to the questions that I raised.
I see no apparent reason why the wiring is not symmetrical, but I'm not knowledgeable enough (and ZERO knowledge about phantom power)
I would breadboard the circuit and experiment with the IC1b wiring
Since you have this pedal, how does that auto power work in practise ?
The pedal turns on only when AC is flowing through the input ?
Or is it jack related ?
Or is it an auto power-off using a time constant?
poiureza
Postby Pollo » 03 Feb 2017, 17:19
I assume the auto power is there to preserve battery life. I haven't really tested it.
When operating on battery, inserting a jack into the input socket connects the battery to the circuit, as you can see in the schematic. It looks like the auto power detects if there is a signal present on the input and then shuts off (after a delay) if there isn't? I'm trying it out now but the power LED stays lit. The other option is that it switches automatically between phantom and battery but then I don't understand why it needs to be so complicated.
Pollo
Next
Users browsing this forum: No registered users and 9 guests
