Roland - AP-7 Jet Phaser  [schematic]
Re: Roland - AP-7 Phaser
Postby chicago_mike » 30 Oct 2009, 15:39
trial and error.
the board "border" line..not the actual board, but the border, is around 4 1/2" by 5 1/2"
and then you play around with that size and your printer. :)
Im almost done with the little board thats inside the ap-7. Nobody ever got a trace side of that board so I am going by schematic and guessing. :oops:
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 303 times
Postby rbstep » 31 Oct 2009, 15:34
I've got everthing for the AP-7 except the little board. If you get it done let me get a copy of the little board file please.....
ron
rbstep
Has thanked: 94 times
Have thanks: 8 times
Postby chicago_mike » 31 Oct 2009, 19:54
Im clening it up today. Right now I am finishing my FX-Blender board.
Gimme like an hour or so. Lets make some of these and make these fuckers 'round har jealous!!!! :mrgreen: :horsey: :twisted:
Skyline FX 2013
chicago_mike
Postby rbstep » 31 Oct 2009, 21:05
I'm with you all the way Mike.....
rbstep
Postby chicago_mike » 31 Oct 2009, 21:32
uhhhh...
1 more hour... :mrgreen:
Skyline FX 2013
chicago_mike
Postby chicago_mike » 31 Oct 2009, 22:08
Almost...
Ill see if I can post the zip file wich will contain the eaglecad files. The traces might be a little small for photo etching, as I have yet to build the small board. Also this is my first REAL complete eaglecad build so if anybody can make it better, go right ahead.
happy halloween all. 8)
Skyline FX 2013
chicago_mike
Postby sevinisthenumber » 27 Apr 2010, 14:41
Anyone have the layout image?
C.S. Lewis
sevinisthenumber
Have thanks: 31 times
Postby chicago_mike » 27 Apr 2010, 14:54
I did a layout of the little board in eagle.
Not verified though.
Ill get one with the parts layout here in a sec.
Skyline FX 2013
For this message the author chicago_mike has received thanks:
modman (07 Jan 2018, 12:37)
chicago_mike
Postby Zokk » 29 Aug 2011, 12:21
Hi
as I've recentely had to repair one, I've took some time to draw the wiring diagram in full colors :D because it's impossible to see anything on the diagram from the service manual.
Take care of the mode swicth which is a dual one (although I don't know the exact reference, does someone know it? dual 2P6T right?). Also the input jack is a DPDT socket, the pin numbers on my drawing are corresponding to a similar socket I've got from Banzai.
Also I don't understand your pcb for the little board Mike... the original is directly soldered onto the bypass stompswitch as you'll see in my drawing. Please could you post your layout?
Anyway I think it'll be easy to populate the main pcb using the layout on the factory schematic (the only little change I've seen is for the trimmer placement, on the main pcb posted earlier in this topic, there are more pads to fit several shapes of modern trimmers). I think that some tracks are too close so the jpg would need a bit of cleaning to be "short-cut"-safe.
So here is the wiring, viewed from component side for both boards:
For this message the author Zokk has received thanks: 3
modman (07 Jan 2018, 12:37), pedalgrinder (31 Mar 2013, 12:58), rbstep (29 Aug 2011, 20:39)
Zokk
Has thanked: 200 times
Have thanks: 67 times
Postby Zokk » 29 Aug 2011, 12:23
sorry don't find that "edit" button:
just forgot to mention that the pots are viewed from their back... as you'll see when you open the original enclosure.
Zokk
Postby seedseed » 22 Nov 2011, 10:28
Hi everyone,
Has anyone got a copy of the service notes still the link up above seems to have disapeared thanks
seedseed
Have thanks: 5 times
Postby grrrunge » 22 Nov 2011, 10:45
seedseed wrote:Hi everyone,
Yes. Here:
roland jet phaser.PDF
For this message the author grrrunge has received thanks: 3
seedseed (23 Nov 2011, 11:44), sinner (22 Nov 2011, 11:10), V1nce69 (22 Oct 2015, 06:53)
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby seedseed » 23 Nov 2011, 11:48
Thank You, Much appreciated, it so good when someone responds like that i can't say thanks enough apparently this unit sounds great on bass so i look forward to making one up. :applause: :horsey: :thumbsup
seedseed
Postby chicago_mike » 21 Jun 2012, 14:52
Ahh!! I forgot this thread!1
The little board is the Gate. Its in updated versions of the jetphase. Its in the pdf.
But I forgot to print out a layout and I lost all that eagle stuff long ago. :slap:
So we would need to redo the gate part.
Skyline FX 2013
chicago_mike
Postby chicago_mike » 21 Jun 2012, 15:07
I thought the switch was 3P5T..but I have known to been wrong. :block:
Skyline FX 2013
chicago_mike
Postby chicago_mike » 21 Jun 2012, 15:15
chicago_mike wrote:I thought the switch was 3P5T..but I have known to been wrong. :block:
Ahh....nevermind. Okay..but I think its 3pole. and 6 position..but i havent slept all day.
Skyline FX 2013
chicago_mike
Postby herwr » 17 Apr 2013, 13:38
Hi guys,
I know this threads been quiet for a little while but I just picked up one of these babies with an apparent fault and want to try and fix her up.
The guy I bought it off stated only three of the switch positions worked correctly and I was wondering if anyone could confirm what type of effect I should be getting in each position.
The following are what happens on mine in the various Mode switch settings:
    1 - Nasal (thin) fuzz effect only (No Phasing)
    2 - Nasal (thin) fuzz effect with Jet Phasing
    3 - Throat (heavy) fuzz effect only (No Phasing)
    4 - Throat (heavy) fuzz effect with Jet Phasing
    5 - Clean(ish) sound (No Phasing)
    6 - Clean(ish) sound with Phasing
I'm guessing Mode 2 / 4 / & 6 are working as they should be and even possibly 1 & 3 if they are supposed to be a Fuzz only effects. However I'm guessing 5 should be doing something other than a clean sound and it makes me wonder if 1 & 3 should do something different as well.
I'd really appreciate if someone could give me an idea of what I'm supposed to get in the various modes? It will really help me (hopefully), to isolate the fault location (if any), as it's hard to work out from the schematic what the switching does or is supposed to do.
Rich
herwr
Postby astrobass » 21 Apr 2013, 07:09
I want one of these so badly but my skills are not yet up to par to attempt cloning it. Still would love to hear any tips on building it though, because eventually, it has to happen.
astrobass
Has thanked: 50 times
Have thanks: 73 times
Postby herwr » 25 Apr 2013, 02:23
@armdnrdy1...
Cheers matey, I can't believe I didn't see that in the manual, I went over the schematic several times trying to figure out where the switch positions connect to, but obviously missed this part.
It seems mine is working on the 'Deep' modulation effect, but not on the Shallow' - Next step to figure out what the difference between 'Deep' and 'Shallow' is in the cct.
Cheers for your help
herwr
Postby armdnrdy1 » 26 Apr 2013, 17:24
herwr,
That should be fairly simple to troubleshoot as the depth is controlled by switching between two resistors.
Look at page four of the service manual. You'll see two images of the AP-7 board, one with component designations (numbers) and one with values.
You want to find R35 (56K) and R36 (220K) Both resistors are located under IC3. Inspect the solder joints and if you have a meter check the resistance of both.
If they check out okay then look to wire pads 10 (yellow wire) and 11 (brown wire), both are located under R35 and R36. Check the wire connections on the pads. Follow the wires up to the "mode" switch. That the big 3 pole, 6 throw
rotary switch. Check the connections of the yellow and brown wire at the switch. Also, visually check the switch for proper function. (make sure it's tight and making contact as it makes it's rounds)
You might also want to check R84 (12K) That resistor can effect the depth as well.
Keep us posted.
For this message the author armdnrdy1 has received thanks:
herwr (28 Apr 2013, 03:56)
armdnrdy1
Have thanks: 68 times
Users browsing this forum: Google [Bot], Google Feedfetcher, NazarDaniel, zzztop and 8 guests
