Tech21 - Character Series.  [schematic]
Re: Tech21 - Character Series.
Postby Fix_Metal » 13 Mar 2013, 12:30
I ended up throwing in the bin that Joyo PCB. Actually it is possible to just modify that but you gotta be EXTREMELY careful during soldering process.
I ordered various samples from TI for SMD 226x ICs and changed up the parts a few times. In the end I was getting bad bias over opamps because of bad contacts which I couldn't resolve. I.e. I tried to isolate one feedback opamp for voltage measure because I couldn't figure out WHY it was not biased. Even if ALL the traces where isolated from other parts I was reading some real Volts. Plus, I had 2 pot chassis sweeped by voltage too, even if they were isolated on the board!!
I think the main problem is the real poor PCB job done on these, that gets worse and worse as soon as you heat it.
Just for having a complete reference about this pedal modification (Joyo over Tech21), here are the missing parts:
-R106 is missing in the British pedal (220K). It is located near U2 and it's R16.
-Bias voltages are all V/2 except for IC2a which is a bit higher (keep in mind that Vcc pass through R37//R38, and ground is elevated by R39//R40, so that what should be +9V will actually be kinda lower, ~7,5V)
-Switching part is shown in this schematic. It is not true bypass and the buffer alters frequencies, so I'd suggest just to get rid of that. There's no reference for diode/transistor as there's nothing written on them, but I'd suggest they are mosfet+zener protection diode (if it was JFET, a diode wouldn't be useful in that place)
-All pots are 100KB
I ended up making my own pcb for the V-Bass and it worked fine at first time. Oh, and I got rid of those Vcc/GND resistors. I think it's just pointless using rail-to-rail technology if you don't run them at full available voltage. The resulting voltage range is actually identical to what you'd expect from straight TL07x/TL06x.
For this message the author Fix_Metal has received thanks:
artaommahe (13 Mar 2013, 17:32)
Fix_Metal
Have thanks: 14 times
Postby Fix_Metal » 13 Mar 2013, 12:31
And btw those switching 2,2uF decoupling caps are SMD ceramics.
Fix_Metal
Postby solarplexus311 » 22 Mar 2013, 20:32
Any idea what the parts differences are for the Oxford?
solarplexus311
Postby GodSaveMetal » 10 Apr 2013, 15:11
rcustoms wrote:I read the whole post and make the pcb, this is now being tested.if everything is working well,i will post it
You made a new one PCB for that you post??? it is working???? 8) please man post it!!! thanks!!! great job!!!!!!! :applause: :applause:
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby rcustoms » 12 Apr 2013, 01:28
soon as i can ,i share the last pcb
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Has thanked: 346 times
Have thanks: 490 times
Postby bajaman » 13 Apr 2013, 07:19
Thought I would revisit this thread and offer some new insight into the Character series gain module :wink:
I decided to simulate just the module (CH34-4) in National Instruments Multisim and examine it's clipping characteristics.
This module is the "guts" of the distortion in these pedals and from what I have seen is identical across the complete series.
There are two stages before the module - first a small buffer or gain stage (depending on whether the unit is in bypass mode or active)
The second stage "character" is a tone shaping pre distortion module stage - this is different for each of the models in the series and is basically what differentiates them all sound wise.
After the CH34-4 module, we have a two stage high frequency rolloff or "speaker simulator" circuit and output level control, which is followed by two fairly conventional post filtering EQ active baxandall Treble Middle and Bass stages.
The final stage is a small op amp buffer.
Anyway - back to the CH34-4 module :wink:
This module uses the LINCMos TLC2262 dual op amp - internally entirely constructed with mosfets - it gain swing the signal full rail before it clips and Tech 21 have used this same device in all of their pedals from the original Sans Amp onward. It has a very soft clipping characteristic and can sound a bit "mushy' in the bass region in my opinion. However it's implementation in the character series pedal is a little different :wink: With reference to the schematics earlier in this thread you may notice two back to back 3.3v silicon zener diodes in the feedback loop of the second stage of the CH34-4 module.
It is THESE zener diodes that clip FIRST in this module according to my simulations NOT the op amp as in the original Sans Amp pedals. These zeners also roll off the high frequency response of this stage - the signal is -3dB down at 5khz and drops to over -22db at 100khz. Without the zeners, the response is flat to 100khz and beyond :shock:
I must emphasize that the signal is attenuated at high frequencies by these zeners EVEN when the signal is NOT being clipped by them :!:
The TLC2262 NEVER has the chance to influence the clipping behaviour in these pedals - all the clipping and high frequency rolloff is performed by the two back to back zener diodes - food for thought :secret:
For this message the author bajaman has received thanks: 7
artaommahe (13 Apr 2013, 23:13), BigTim (02 Jun 2015, 21:33), deltafred (13 Apr 2013, 08:57), HENK (13 Apr 2013, 11:44), mister707 (17 Apr 2013, 00:57), rbstep (15 Apr 2013, 13:04), x-tn (13 Apr 2013, 22:31)
Has thanked: 437 times
Have thanks: 1499 times
Postby bajaman » 15 Apr 2013, 10:27
not sure about the cap values - resistor values and cabsim switching is correct though.
A few more surprises compared to the earlier models before the cabsim switch was fitted :wink:
enjoy :hug:
For this message the author bajaman has received thanks: 6
artaommahe (15 Apr 2013, 13:43), dorrisant (17 Mar 2017, 18:33), HENK (15 Apr 2013, 15:43), JiM (12 Mar 2016, 14:12), karul (15 Apr 2013, 13:01), mister707 (17 Apr 2013, 00:57)
Postby bajaman » 15 Apr 2013, 12:49
I would suggest trying a value of 1n (possibly more) for the capacitor marked with a ?
This sets the high frequency rolloff when the speaker simulator cabsim switch is disengaged.
For the suggested value the high frequency response will be approximately -3db down at 8KHz.
Double the value (2n2) and the response will be -3db at 4Khz.
Postby artaommahe » 15 Apr 2013, 17:46
bajaman, oh.. thanks ) speakersim bypass is from real pcb?
artaommahe
Has thanked: 18 times
Have thanks: 2 times
Postby artaommahe » 15 Apr 2013, 17:52
bajaman, any chances on us steel? =)
artaommahe
Postby bajaman » 15 Apr 2013, 21:36
yes :D
sorry - I have not seen that one yet - someone did post some gut shot pictures in another thread on this forum, but I have been unable to view them - sometimes images just seem to disappear :cry:
If anyone has these pictures, would they please repost them in this thread. :thumbsup
Postby bajaman » 16 Apr 2013, 05:12
For this message the author bajaman has received thanks: 2
GodSaveMetal (16 Apr 2013, 21:03), mr coffee (25 Mar 2018, 21:58)
Postby bajaman » 16 Apr 2013, 05:14
GodSaveMetal (16 Apr 2013, 21:03), mister707 (24 Dec 2013, 02:02)
Postby bajaman » 16 Apr 2013, 05:17
GodSaveMetal (16 Apr 2013, 21:04), mister707 (24 Dec 2013, 02:02)
Postby bajaman » 16 Apr 2013, 09:09
:oops: I left R14 off yesterdays schematic - here is the corrected version revision 1
mister707 (17 Apr 2013, 00:56)
Re: Tech21 - Character Series.  [schematic]
Postby bajaman » 16 Apr 2013, 09:51
I corrected the cabsim filter capacitor values (C14 and C15) - these are the same as the British pedal which emulates the Celestion greenback response. it seems reasonable to assume these will be the same in the Oxford which according to the builders has the same loudspeaker simulator.
Here is revision 2 :D
12Bass (17 Apr 2013, 14:01), dorrisant (17 Mar 2017, 18:34), GodSaveMetal (29 Apr 2013, 00:57), lespos (05 Jul 2013, 13:14), mister707 (17 Apr 2013, 00:56), nikos_sophos (21 Apr 2013, 19:26)
Postby bajaman » 16 Apr 2013, 10:15
an interesting observation - C13 and R16 introduce a -6db gradual rolloff in the bass response EVEN when the cabsim is bypassed. At 900Hz this filter has little effect on the response curve, but by 100Hz the output level has been gradually reduced so that at low frequencies the response is -6db down. If this filter is removed, the response is flat from 900Hz down to 100Hz :wink:
GodSaveMetal (29 Apr 2013, 00:58), mister707 (17 Apr 2013, 00:56)
Postby artaommahe » 16 Apr 2013, 16:45
bajaman, at pdf schematic from first pages(liverpool) we see that there is no one part of circuit - after speakersim (10k -> 10k_gnd -> 1u ->10k). It's from original pcb?
Also what do you think about Blend pot realization at VT Bass DI?
artaommahe
Postby Fix_Metal » 29 Apr 2013, 00:38
I forgot to update the topic. First, there's a errata in the E1 value, it's definitly 10nF. Let's start from this.
Code: Select all
        |                    T e c h   2 1                     |                  J O Y O                  |
        | Blonde  | British | California | Liverpool | VTBass  | American | British | California | AC Tone |
R4      | *3.3k   |   10k   |            |   3.3k    |  3.3k   |   *10k   | 10k(R4) |            |   10k   |
E1      |  open   |   18n   |            |    22n    |  10nF  |   open   | 18n(C3) |            |   22n   |   Input &
Cin     |   22n   |   22n   |            |    22n    |  22n    |    22n ? | 22n(C1) |            |   22n   |  filtering
C2      |   47n   |   47n   |            |    47n    |  open   |    47n ? | 47n(C2) |            |   47n   |
C5      |   22n   |   10n   |            |    22n    |   10n   |    22n   | 3n (C8) |            |   22n   |
C6      |   22n   |   10n   |            |    22n    |   10n   |    15n   | 82p(C7) |            |   22n   |
R6      |    1k   |    1k   |            |     1k    |    1k   |     1k ? | 1k(R6)  |            |    1k   |  Character
R7      |  100k   |  100k   |            |   open    |  100k   |   100k   | 100k(R7)|            |  100k   |   pre-EQ
R9      |    1k   |  3.3k   |            |   3.3k    |  3.3k   |   3.3k   |3.3k(R10)|            |  3.3k   |
R14     |   47k   |   33k   |            |    47k    |   33k   |    33k   | 33k(R24)|            |   33k   |
C14     |  470p   |  470p   |            |   180p    |   470p  |     ?    |470p(C17)|            |    ?    |  HP sim
C15     |  2.2n   |  2.2n   |            |   2.7n    |   2.2n  |   2.2n   |2.2n(C18)|            |  4.7n ? |
C20     |   10n   |   22n   |            |    18n    |   10n   |    15n   |15n(C25) |            |   18n   |   MID
C21     |   10n   |   22n   |            |    22n    |   10n   |    15n   |22n(C24) |            |   22n   |    EQ
*Not used
Then I followed the advices of 12bass guy, found in this topic:
1) 22K resistor accross high pot, between lugs 1 and 2 (or maybe 3 and 2? who remembers :mrgreen: )
2) DPDT simcab with pre sim on R14, R15 etc., the other wired to level pot and put a 10nF over ground when the switch is engaged
3) Put a 100K log instead of linear pot in volume (odd enough, the pedal had so much volume already at 1/10 with linear)
Great work bajaman, sorry for the interruption :applause:
Fix_Metal
Postby bajaman » 29 Apr 2013, 01:15
I just bought a JOYO California sound pedal - couldn't resist the $1.00 price tag (plus US$32.00 for shipping - hah ah :wink: )
First impressions were very favourable - I changed the dual op amp (TL062) - put a TLC2262 in it's place - i left the other two quad op amps (TL064).
May get around to tracing the component values but a this price - just buy it and do the mod :wink:
Users browsing this forum: bifurcation, Cwhittin, Google Feedfetcher and 7 guests
