Chandler - Tube Driver (rack version)  [schematic]
Postby DahakaNishoba » 03 Oct 2009, 00:19
Ok I got a RACK VERSION of a rev1 chandler tube driver...BUT...this has been modified by the previous owner
He's an acoustic guitar master and used this ONLY as a preamp...so asked a tech to modify this to REMOVE any drive or distorte signal
I can provide gutshots of everything inside but its modified so the request is
ANYONE HAS a PCB LAYOUT/PHOTO/ or actually a rack like the one I have...just Open it and give me some info
i cant really see any sign of mod (apart from some "new" resistor or unsoldered holes in the pcb ) but without anything of original ones its really hard to do something
Again i can post pics if anyone is interested...is a rack version with
DRIVE
BIAS
MASTER
CONTOUR
3 EQ
The way electronics work in a stompbox is like the way pixels move in a videogame
it's Magic, in Technology
DahakaNishoba
Re: Chandler RACK Tube Driver (HELP)  [schematic]
Postby Dirk_Hendrik » 03 Oct 2009, 09:13
Photo's? A few shots on the wiring only.
preps this helps:
http://www.dirk-hendrik.com/temp/Chandler_Tubedriver_Rack.pdf
For this message the author Dirk_Hendrik has received thanks: 2
Intripped (30 Jan 2018, 12:34), juice2 (04 Feb 2018, 12:21)
Has thanked: 253 times
Have thanks: 1015 times
Postby DahakaNishoba » 03 Oct 2009, 13:25
ok that was WAY helpful
now I have something to work with.
anyway I just unmounted/unscrewed the pcb pots and jacks....everything seems at his place...even solder joints....seems "original" but the sound is WAY different than an original one... :hmmm:
anyone has a shot of both sides of pcb ? (or even only component side) at least I wanna kno if a pair of unsoldered ground pads are normally empty or theres something wrong
DahakaNishoba
Postby Dirk_Hendrik » 03 Oct 2009, 14:31
DahakaNishoba wrote:ok that was WAY helpful
I serviced one of these a few weeks ago. (hence the schem) Shoot some pics and I'll tell you more if I can.
Edit; the owner sent me pics prior to shipping the unit:
Postby Dirk_Hendrik » 03 Oct 2009, 14:39
and now you have all I have ;)
Intripped (30 Jan 2018, 12:35)
Postby DahakaNishoba » 03 Oct 2009, 19:23
Hmmmm huge thanks....ok so there are empty pads even in original one...I can't notice nothing major...just a different transformer (mine seems newer or just in better conditions....will shoot some macro of the inside tomorrow mornin...
DahakaNishoba
Postby sadrew » 08 Nov 2011, 11:31
Hi everybody,
I am in the process of making a diy project for this little beast!
I am redrawing Dirk's schematic on Eagle and next step will be making a board layout, obviously available for everyone.
I am asking if someone would be so patient to contribute and give a look to my schematic. I am mostly interested in checking potentiometers orientation, jacks normalling and spotting overall mistakes.
Many thanks in advance
sadrew
Have thanks: 15 times
Postby sadrew » 08 Nov 2011, 11:36
It seems I can't upload the schematic in the attachments... What's happening?
sadrew
Postby sadrew » 08 Nov 2011, 12:14
Here it is
For this message the author sadrew has received thanks: 6
beginwhereUR (14 Oct 2013, 04:52), deltafred (09 Dec 2011, 11:09), joeboo88 (09 Dec 2011, 14:31), Manfred (06 Jun 2013, 22:05), sinner (08 Nov 2011, 12:32), stojanos (30 Jan 2018, 11:48)
sadrew
Postby sadrew » 11 Nov 2011, 13:21
come on guys! :roll:
sadrew
Re: Baja B K Butler Tube Driver
Postby sssteeve » 09 Dec 2011, 09:55
I was wondering if anyone has a schematic for the Chandler rack mount TDR-101 Tube Driver. It is quite different from the original 4 knob pedal- which I bought in 1986/7 but traded in a year later for the rackmount version. :slap: (I should have gotten suspicious when the store was offering me the full price I had paid for it toward the "new and improved" model... in most cases it would have been 50-70% of what I paid originally.)
I thought that the rackmount version was too harsh so I added a cap or two (somewhere!) to mellow things out. I'm glad to have found the schematics for the original 4 knob floor pedal here- I hope to rewire my rackmount POS as the 4 knob floor pedal. (One good thing about the rackmount version was the boost switch- I may try to incorporate that into the good design.)
Thanks for all of the great information on the Tube Driver!
Steve Ahola
P.S. About 15 years ago I got a box of 3 or 4 broken rackmount TDR-101's from Dan Torres for $10 so now that I have the real schematic I will see what I can do with them! (I just need to remember what I did with that damn box!)
Reason: Post moved to Chandler Rack thread : have a little search next time... ;)
The Blue Guitar
www.blueguitar.org
sssteeve
Have thanks: 5 times
Postby Bernardduur » 06 Jun 2013, 20:51
@ Dirk; I traced a repair here. Only difference with your unit is R17. That resistor here is only 2k2 (22k in your unit).
Bernardduur
Has thanked: 87 times
Have thanks: 484 times
Postby Vicus » 11 Jun 2013, 12:20
Does some one have the schematic of RT-913? The six knob version.
Vicus
Postby Manfred » 19 Jun 2013, 21:43
Vicus wrote:Does some one have the schematic of RT-913? The six knob version.
Sorry, the RT-922 only.
Manfred
Has thanked: 987 times
Have thanks: 532 times
Postby stojanos » 30 Jan 2018, 11:56
sadrew wrote:Here it is
Can you send me the eagle schema file that you created ? I would like to build a PCB layout from schema and not from image files that can be found on Baja post. I promise that I will share it here.
Thanks.
stojanos
Have thanks: 9 times
Users browsing this forum: bnm and 14 guests
