Page 1 of 3
Ibanez - TS-9DX Turbo Tube Screamer
Posted: 25 Dec 2009, 00:23
by Jack Deville
Try as I might, I could NOT find a schematic on the internet. Service manual is available, but it does not detail the operation of the "MODE" switch, and does not provide a schematic. So, I traced it.
Finally! I schematic detailing the inner workings of the elusive TS9DX, and associated modes. All in all, its a Tube Screamer. Surprised? There are some unique qualities to the TS9DX, and some of the modes may surprise you.
Without further ado, here is the schematic. Now the internet has a reference. Enjoy!
(Updated schematic below)
Re: TS9DX Turbo Tube Screamer
Posted: 25 Dec 2009, 05:07
by bajaman
I think there should be a link wire between the mode switch sw1a and sw1b common terminals
ps: thanks
Posted: 25 Dec 2009, 06:19
by Jack Deville
Right on all accounts. Sorry guys. I got lazy and forgetful.
I'll make corrections, add the bypass circuitry and additional notes specifying opamp and any other pertinent information.
As far as the dual-ganged 250k pot, WTF? It works, right? Maybe it was readily available and/or cheaper than a 500k? I thought it was a little strange/unusual as well.
Updates to follow.
PS: bajaman, I don't follow your suggestion. Can you expand? SW1A selects clipping diode options (or lack thereof in the "TURBO" mode) while SW1B selects feedback loop bypass cap. Did I mis-understand you, or make and error?
Posted: 25 Dec 2009, 07:28
by Dirk_Hendrik
error
There should still be a connection from those caps to the inverting input of the opamp. Check a standard TS schem for reference and see how they've added the switch and you'll see what Baja means.
Re: TS9DX Turbo Tube Screamer [schematic]
Posted: 25 Dec 2009, 08:08
by Jack Deville
Updated.
If any further errors are present, please advise. I will correct them and add bypass circuit.
Posted: 26 Dec 2009, 15:20
by stonew
Posted: 31 Dec 2009, 02:11
by TubeDude22
Very interesting. Thanks!
Posted: 03 Jan 2010, 06:19
by jumper
TS9-DX schematic ?
Posted: 16 Mar 2010, 04:33
by okgb
Just different networks switched into the fb loop ,
anyone seen the schematic [ and/or what analogman does ]
As simple as two wires going going to the switch ?
thanks , regards Greg
Re: TS9-DX schematic ?
Posted: 20 Mar 2010, 01:44
by collingtech
yes i had this...somewhere in my hds (3 x500gb) il post soon , what mod you loocking for? drive?tone?
Posted: 20 Mar 2010, 11:25
by JHS
Just a stock TS with switchable Cs on the R/C-network and switchable FB-loop clippers.
Stock TS9DX:
the 4.7k R is unchanged in all modes
TS9-mode: 0.047nF+2 Si-diodes
+mode: 0.22nF +4 Si-diodes
hot-mode: 1.0nF+2 red LED+470kin parallel with the LEDs
(I'm, not sure about this, 'cos I've seen a DX with 4 Si-diodes in this mode and no 470k)
Turbo-mode: 2.2uF+none diodes
Analog Man TS9DX:
classic and silver mod on request and mode-mod
+mode: 0.1nF+4 Si-diodes
hot-mode: 0.1nF+3 Si-diodes
Turbo-mode: 0,22nF+3 Si-diodes
The keeley mod is similar. You can find info about his mod on the web. Use google.
JHS
Posted: 24 Mar 2010, 04:16
by Jack Deville
I can't believe I'm saying this:
Use the search function.
After searching and searching, I could not find a schematic of this pedal. So I traced it.
https://www.freestompboxes.org/viewtopic.php?f=1&t=8179
Bypass is omitted. Its the standard Ibanez flip-flop circuit.
Enjoy!
Posted: 24 Mar 2010, 07:52
by roseblood11
What sense does that dual gang drive pot make? Wouldn´t a simple 500k pot give the same results?
Posted: 24 Mar 2010, 07:59
by Jack Deville
Yes, roseblood. It would perform the same function.
It struck me as odd when I saw it, but that's what's in there. Maybe they had a huge stock-pile of dual ganged pots, or maybe they were super cheap or maybe.... you get the idea.
Who knows. Works the same.
Posted: 11 Apr 2010, 14:29
by okgb
Thank you , was mostly curious about how they implimented the switching
but nice job on the schematic [ and now new internet reference ]
i would have paid for that .
what program did you use to make the schematic btw ?
Posted: 13 Apr 2010, 15:29
by Jack Deville
Never pay for schematics!
Glad I could contribute to the stockpile of information we all have available to us. I have benefitted greatly from said information. Proud to finally give back in my meager way.
The schematic was created using Express Schematic.
It is available for FREE here:
http://www.expresspcb.com/ExpressPCBHtm ... ftware.htm
Posted: 13 Apr 2010, 16:47
by Dirk_Hendrik
Jack Deville wrote:Never pay for schematics!
uuh..
I sometimes do.
When paying a few bucks saves me hours of tracing for example. Or when I get the real service manual including setup procedures.
Posted: 13 Apr 2010, 22:49
by Jack Deville
caveat:
If you can possibly avoid it
Most stuff I come across is readily available, with a few exceptions. Those are the bummers. This schematic eliminates one of em.
Posted: 04 May 2010, 21:19
by mookie
I hope you don't mind me posting this question here but I was hoping someone may be able to help. I'm currently repairing a turbo tube screamer that's taken a kick on stage and damaged the drive pot. I've spent a good coupe of hours now searching manufacturer and parts site for a replacement and I'm not having any luck. The alps web site doesn't even list a 250k pot in any of the dual gang versions I can find. Has anyone got any ideas as to where I might be able to get on. Or failing that a 500k that I can use in it's place.
Thanks for your time and all the great schematics
Posted: 05 May 2010, 00:39
by Jack Deville
http://www.mouser.com/ProductDetail/Alp ... ioJOdsA%3d
I don't remember the model used. Just a shot in the dark.
