Ibanez - TS-9DX Turbo Tube Screamer  [schematic]
Re: TS9-DX schematic ?
Postby dai h. » 21 Jul 2010, 16:04
just stumbled into this (service manual) :
http://www.ibanez.com/parts/2004_PARTS/ ... /ts9dx.pdf
dai h.
Has thanked: 42 times
Have thanks: 11 times
Re: TS9DX Turbo Tube Screamer
Postby okgb » 21 Jul 2010, 17:38
closer with the block diagram , but
not as good as Jack's work , thanks
good to see voltage references
okgb
Has thanked: 189 times
Have thanks: 41 times
Postby dai h. » 22 Jul 2010, 09:49
It obviously doesn't contain a schematic. The point of posting that is that it offers something different. Sorry that is not appreciated.
dai h.
Postby okgb » 22 Jul 2010, 15:02
Who you talking to ? I said thanks
thanks to you all , infact
okgb
Postby dai h. » 22 Jul 2010, 16:58
okgb wrote:closer with the block diagram , but
The link I posted is a service manual which obviously contains no schematic. So why compare the two in the first place? As as I said, these are different things to be appreciated in a complementary/supplementary way, not as some competition on who can post the best schematic or whatever.
dai h.
Postby bilbo_moria » 15 Nov 2010, 21:34
Jack Deville wrote:Updated.
If any further errors are present, please advise. I will correct them and add bypass circuit.
Just modding my TS9DX.
In my pedal, C120 (Mode +) is electrochimic 2.2uF (just like in Turbo mode)
bilbo_moria
Re: Boss - TS9DX Turbo Tube Screamer
Postby srv » 08 Dec 2010, 14:23
Thanks for all the info.
I just pulled apart my TS9DX to compare it with a stock TS9 which I have modded for a friend.
I also wanted to know how they did the switching between modes
and here are the values in mine :
Stock TS9DX:
the 4.7k resistor is unchanged in all modes
TS9-mode:
47nF (.047uF) + 2 x Si-diodes (Capacitor is marked 473, EIA code shows this as 47nF)
+mode:
220nF (0.22uF) + 4 x Si-diodes
hot-mode:
1uF + 2 red LED + 100kin parallel with the LEDs
Turbo-mode:
2.2uF + no diodes
The Drive pot is a dual ganged pot, I suspect they used it that way because they already had the parts in stock.
As used in the Super Tube Screamer.
(The one with two JRC4558 IC chips)
srv
Postby PmCimini » 08 Dec 2010, 17:21
Could someone change the thread's title from Boss to Ibanez?
PmCimini
Has thanked: 24 times
Have thanks: 3 times
Postby lolbou » 08 Dec 2010, 17:36
PmCimini wrote:Could someone change the thread's title from Boss to Ibanez?
Makes sense... :wink: (The error came from some merging of topics).
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 346 times
Have thanks: 235 times
Re: Ibanez - TS9DX Turbo Tube Screamer
Postby fosterocalypse » 28 Dec 2010, 19:41
hey guys...new to freestompboxes.org but I got a pedal with a broke level pot. I am having 0 luck with finding a place I can order a replacement at....does anyone have any idea?
fosterocalypse
Postby lolbou » 28 Dec 2010, 20:59
fosterocalypse wrote:hey guys...new to freestompboxes.org but I got a pedal with a broke level pot. I am having 0 luck with finding a place I can order a replacement at....does anyone have any idea?
...for a TS9DX?
lolbou
Postby fosterocalypse » 06 Jan 2011, 05:27
yes. I have dug through a ton of websites and ebay etc ordered some 100k pots from a seller that the pic looked close but i just got it in the mail today and it is basically just a standard mini-pot.
fosterocalypse
Postby tombel » 26 Mar 2012, 13:08
just joined this forum, not sure how to navigate, can't find ts9dx scematic....
tombel
Postby okgb » 26 Mar 2012, 13:32
On the previous page , start from the first post of this thread
no search required .
I'd never seen a real TS9 DX schematic , But Jack Deville drew the one here , just as good
which really the only main [ only ? ] difference from a TS9 is the switch & diode /cap combinations
okgb
Postby GodSaveMetal » 23 Aug 2012, 03:21
please somebody has a mode for KEELEYS mode ts9dx flexi 4x2 guide???
Thanks a lot :mrgreen: :mrgreen:
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby sregal » 04 Nov 2012, 21:48
OK, great! But, how do I figure out which diodes match what modes. It's clear that "LED 1" and "LED 2" go with the "hot mode". Can someone clarify the following:
D101 & D102= ________ mode
D111, D112, D113, & D114.... which are paired with which mode?
sregal
Postby GodSaveMetal » 06 Nov 2012, 20:19
Please!!! Some body post a photo of a TS9DX inside guts of this pedal?? all the inside, the circuit, the PCB, the pots PCB, and the selector details??? THANKS a LOT!!!!
GodSaveMetal
Postby bufferbrad » 09 Sep 2013, 16:32
So, my TS9dx isnt functioing, no result when switch is pressed. I began testing the power and noticed that across the indicator led the voltage dropped by 1.5 volts to 7.4 or something like that. Is this my issue? Should i change my led?
bufferbrad
Postby okgb » 09 Sep 2013, 19:00
I'd say try cleaning the " micro " switch first , and maybe replace it [ it's a little switch that the pedal depresses ]
I'll post my DX-9 but it's a modded one
okgb
Postby GodSaveMetal » 09 Sep 2013, 19:26
GodSaveMetal wrote:Please!!! Some body post a photo of a TS9DX inside guts of this pedal?? all the inside, the circuit, the PCB, the pots PCB, and the selector details??? THANKS a LOT!!!!
Please somebody??? please the pots and the main PCB please please!!!!
All the Photos you can!!!!!!!!!!!
GodSaveMetal
Users browsing this forum: chinpo, jefouc and 17 guests
