Ibanez - TS-9DX Turbo Tube Screamer  [schematic]
Re: Ibanez - TS9DX Turbo Tube Screamer
Postby okgb » 10 Sep 2013, 17:18
this is one I copied off an analogman modified , so not stock , and fk I hate photobucket
For this message the author okgb has received thanks: 2
dai h. (10 Sep 2013, 21:47), floris (17 Oct 2013, 20:11)
okgb
Has thanked: 184 times
Have thanks: 39 times
Postby bufferbrad » 10 Sep 2013, 22:03
The switch problem seems to be a more logical answer now since signal is being passed through the pedal, its just not screaming!!
Does anyone know what kind of switch the micro switch is? or would a regular stomp box switch work if i mounted it through the top?
bufferbrad
Postby okgb » 11 Sep 2013, 15:21
This could be your chance to go from electronic switching to true bypass 3pdt , although it
maybe wise to determine the problem first , I say try cleaning the switch as an easy step
the switch part itself is not expensive , local music store repair dept may have it .
Let em know if you want anymore pix before I put it back together , regards Greg
bufferbrad (11 Sep 2013, 16:54)
okgb
Postby bufferbrad » 13 Sep 2013, 00:44
switched out the switch. Works like a charm. Thanks for the help man, got a key component of my signal flow back. now i gotta fabricate some new way to secure the spring, ehhhh.
GodSaveMetal, if you need a unmodified PCB pic, i might be able to help
bufferbrad
Postby GodSaveMetal » 13 Sep 2013, 01:28
bufferbrad wrote:switched out the switch. Works like a charm. Thanks for the help man, got a key component of my signal flow back. now i gotta fabricate some new way to secure the spring, ehhhh.
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!! thanks, post all the pics , conectors, circuit all in details; thanks man!!!!!
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby GodSaveMetal » 24 Sep 2013, 02:38
Please bufferbrad I´m waiting for your help, PHOTOS; service notes etc etc!!! :shock: :shock:
GodSaveMetal
Postby noiseuoh » 21 Mar 2014, 15:12
so i built a ts9dx based on tagboard effects layout
http://tagboardeffects.blogspot.fi/2013 ... eamer.html
the only problem is that when in the turbo mode and the drive is up passed half way it turns into a slow kind of tremolo. like the sound kicks in and out. would anyone have any idea why this could happen? too much gain hitting the opamp? someone else had the same problem so i know its not a build error. the other modes work fine so im pretty sure its not a layout problem.
does anyone have an explanation?
noiseuoh
Have thanks: 4 times
Re: Ibanez - TS-9DX Turbo Tube Screamer
Postby Bernardduur » 16 Jan 2016, 21:21
I've also got one; quite pleased with it.
My IC is a JRC4558; no mods have been done to this unit
Bernardduur
Has thanked: 85 times
Have thanks: 470 times
Postby mictester » 18 Jan 2016, 02:43
Just for the sake of amusement, I built something similar to this, but with a 4066 to select the type of clipping, and a couple of gyrators for the tone controls. I was pleasantly surprised by the results. The IC line-up is a 4558 for the clipper part, a TL074 for the input and output buffers and the two gyrators, two 4066s - one for bypass and the other for clipping selection and a 4013 for the bypass on / off. It's a neat, small PCB, and appears to be mostly full of ICs! All the controls are 500k and 50k linear with tapering resistors where required.
I suppose I should put it in an expensive box, thoroughly goop it, and sell it at some exorbitant price as the "ultimate" boutique device! The boobs at TGP will fall over themselves praising what is - essentially - just another Tube Screamer!
mictester
Has thanked: 32 times
Have thanks: 785 times
Postby roseblood11 » 18 Jan 2016, 03:53
schematic or it didn't happen...
roseblood11
Has thanked: 330 times
Have thanks: 304 times
Postby mictester » 18 Jan 2016, 11:37
roseblood11 wrote:schematic or it didn't happen...
It's in my notebook. I'll scan it and post it later today.
mictester
Postby friendrix » 20 Mar 2017, 10:23
I've made a good photos of TS9DX and wrote caps and transistors values.
Also I've combined two sides of PCB for easier tracing.
friendrix
Postby roseblood11 » 20 Mar 2017, 11:45
Read the thread...
You'll find the schematics and links to different layouts.
roseblood11
Previous
Users browsing this forum: johncatoline13, Sir Fayzalot and 7 guests
