DO NOT post requests or debugging in this forum. please.
Postby culturejam » 22 Nov 2009, 22:18
Pretty please, with sugar on top.
Don't post in this forum asking is there is a schematic or layout or info on XXX pedal.
There is a subforum setup for requests already. It is located here:
REQUESTS FORUM
Any requests posted here will be moved to proper sub forum, and I'll also make nasty remarks about your mother. :mrgreen:
also, if you have a problem with your build, post it in the WORKBENCH. these threads are for circuit analysis only. by all means, if you discover something we should know, post away after you have it figured out. but, if it is a simple debugging, keep it in the 'bench. thank you.
Reason: added debugging message.
culturejam
Has thanked: 462 times
Have thanks: 582 times
Re: DO NOT post requests in this forum. Pretty please.
Postby lolbou » 22 Nov 2009, 22:23
And if your request is fullfilled, then we'll be happy to move it back where it belongs...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 347 times
Have thanks: 240 times
Users browsing this forum: Google [Bot] and 9 guests
