Danelectro - N-10 Honeytone amp  [schematic]
Postby markbr4769 » 18 Mar 2010, 00:45
Hello,
I have traced out circuit of the Danelectro Honeytone guitar amp.(attached). The preamp is a TL072. Can anyone help me understand what the main parts of the circuit are doing.
I know increasing R11 inceases gain. I checked the diodes too - initially thought they were soft clippers but they dont seem to be doing anything, there wasn't a difference when the were removed. Do you know what they are for then? Also,
1) what do: R2 and R9 do?
2) how is the tone control part working (ie R6, R7, C7, C8, C9, C11)?
Im pretty new to all this but im learning so i'll really appreciate it if someone could help explain it! Thank you.
Reason: deleted schematic for the reason of an updated version
markbr4769
Re: What are these parts doing?
Postby analogguru » 18 Mar 2010, 01:14
The schematic is wrong:
R3 will be 5k6 (or R14 47k). R3 and R14 form a "bias divider" to obtain a voltage half of the power supply which is needed for proper operation.
This bias voltage is fed to the op-amp input via R2 and R9 - thats their function.
There are missing some components around the first op-amp - have a look again.
Have thanks: 116 times
Postby markbr4769 » 18 Mar 2010, 03:05
Analogguru,
Thank you for your reply, R4 is 47K not 4.7K as on the schematic. R3 is 56K. I've uploaded a corrected one. I've re-checked the components, they're no missing components. I've also duplicated this schematic onto a breadboard and it sounds fine. Now that R3 and R4 form the bias divider that halves the supply voltage, why are large R2 and R9 values needed before being fed to the non-inverting op-amp inputs? Im still unsure about the diodes though, as they dont cause clipping at all. In this circuit distortion is obtained only by turning the overdrive pot all the way up so that it hits the supply rails. Im wondering how i can add clipping at low volumes.
markbr4769
Postby markbr4769 » 18 Mar 2010, 03:06
here's the corrected schematic
For this message the author markbr4769 has received thanks:
Andy2No (13 Jan 2019, 23:46)
markbr4769
Postby soulsonic » 18 Mar 2010, 03:11
there MUST be something else connected to pin 6 of the TL072. I cannot see how it will function correctly without the proper connection to ground there. There should at least be a resistor connected between pin 6 and ground.
Has thanked: 56 times
Have thanks: 276 times
Postby markbr4769 » 18 Mar 2010, 03:24
:shock: Im sorry, i forgot to connect R5 and C5 to pin 6 when drawing the schematic. (I've been working on this circuit the whole day i've become careless!) I've reuploaded the schematic above :)
markbr4769
Postby soulsonic » 18 Mar 2010, 09:42
Ah! Now it works! :D
Postby Güero 2.0 » 18 Mar 2010, 13:16
For this message the author Güero 2.0 has received thanks:
Güero 2.0
Have thanks: 25 times
Re: Danelectro - Honeytone
Postby Greg » 18 Mar 2010, 14:05
Aren't the clipping diodes on a switch ?
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby markbr4769 » 18 Mar 2010, 18:33
No, the diodes are not on a switch...and i as far as i know they dont cause clipping at all. When they're removed the sound stays the same. Clipping only occurs when the sound signal hits the supply rails. So im still wondering what these diodes are for. When the tone pot is turned all the way down, wouldn't the capacitors C7, 8, 9, 11 short thus the diodes could be there as some kind of protection mechanism? Im only guessing but could this be correct?
markbr4769
Postby Greg » 19 Mar 2010, 01:08
markbr4769 wrote:No, the diodes are not on a switch...and i as far as i know they dont cause clipping at all. When they're removed the sound stays the same. Clipping only occurs when the sound signal hits the supply rails. So im still wondering what these diodes are for. When the tone pot is turned all the way down, wouldn't the capacitors C7, 8, 9, 11 short thus the diodes could be there as some kind of protection mechanism? Im only guessing but could this be correct?
The diodes run from the output of the 1st stage of the TL072 to ground, so they will certainly clip whenever the signal level is high enough.
I see now that they're controlled by the level of Drive from that stage rather than a switch.. so as you turn up the Overdrive knob they're brought into play, and you should definitely be able to hear their effect when Overdrive control is turned up.
Greg
Postby markbr4769 » 21 Mar 2010, 15:43
Greg_G wrote:The diodes run from the output of the 1st stage of the TL072 to ground, so they will certainly clip whenever the signal level is high enough.
I think you're right about the diode clipping. I checked it the output from pin 1 with an oscilloscope. The input was a 1Khz sine wave from the signal generator. The volume and overdrive pots were turned up only slightly about 20-25%. The oscilloscope readings are attached.
With two 1N4148 diodes --- peak-to-peak voltage is 2.88V
With two germanium diodes --- peak-to-peak voltage is 1.92V
With diodes removed --- peak-to-peak voltage is 5.72V
The diodes definitely reduce the voltage measured at pin 1. Am I right to say they cause clipping?
markbr4769
Postby deegeedoil » 12 Dec 2012, 11:04
For this message the author deegeedoil has received thanks:
modman (25 May 2015, 21:49)
deegeedoil
Re: Danelectro - N-10 Honeytone amp  [schematic]
Postby blackcorvo » 08 Jun 2015, 03:19
Even tho this is a very old thread, I felt it would be better to continue it here rather than posting on a new one.
After taking a look at my own Honeytone and later confirming it with pictures of the PCB from http://batterypoweredguitaramp.com/dane ... amplifier/, I noticed the preamp's second op-amp resistors were wrong on the schematics posted on this thread. They were supposed to be 1k/2k2 instead of two 33k (you can see them on the pictures from that link, they're on the left side of the TL072, labeled 102 and 222).
I re-drew the schematic myself, but since I have no ways of measuring the SMD capacitor values to confirm if they are correct, I decided to keep the ones from the circuit posted before on this thread, as the tone control circuit itself is constructed the same way.
Here's the schematic:
I personally like this amp a lot, and I'm considering making a "serious" version of it using a TDA7240 for the power amp. I already did try the circuit on a protoboard and the results were nice, and after that I made a layout but haven't built anything definitive yet.
For this message the author blackcorvo has received thanks:
modman (08 Jun 2015, 11:01)
blackcorvo
Have thanks: 16 times
Postby blackcorvo » 14 Jul 2017, 16:36
The picture is down from the link I posted previously, but I still have it here:
And just in case it goes down, I have it on my Google Drive as well:
https://drive.google.com/file/d/0B08phn ... sp=sharing
For this message the author blackcorvo has received thanks: 3
deltafred (14 Jul 2017, 18:43), Manfred (14 Jul 2017, 21:29), mirosol (03 Dec 2017, 09:57)
blackcorvo
Postby mirosol » 03 Dec 2017, 09:59
Drew this on a stripboard in case some might want to tweak it. I suspect it'll be a nice 1 watter, if one gives it a decent speaker cone and a wooden housing.
For this message the author mirosol has received thanks:
Manfred (03 Dec 2017, 17:39)
mirosol
Has thanked: 157 times
Have thanks: 365 times
Postby Ichabod_Crane » 21 Jul 2018, 18:36
It's still no verified :(
Ichabod_Crane
Has thanked: 16 times
Have thanks: 6 times
Postby rayandkerry » 25 Oct 2018, 20:50
Hi all. First time post for me.
A couple questions...
1. What do the blue dots mean on the tagboard with just the links and cuts?
2. What about the headphone jack? Is that basically just attached to the speaker outputs (using a switched headphone jack to cut off the speaker when the headphones are being used)?
Any help folks can offer would be greatly appreciated. Thanks!
rayandkerry
Postby Ichabod_Crane » 25 Oct 2018, 21:28
1. Those blue dots mean that the links (or jumpers) go in the same hole.
2. It could be like you said, but I'm sorry, I'm not sure about it. Try to compare this schematic with some version of the Ruby with headphone output included.
Ichabod_Crane
Postby rayandkerry » 25 Oct 2018, 22:01
Ichabod_Crane wrote:1. Those blue dots mean that the links (or jumpers) go in the same hole.
Sweet, thanks!
Did a little research and basically I think what I was proposing would work but be extremely loud in the headphones. But I read that you can reduce the headphone volume by placing a resistor from the sleeve of the headphone jack to ground. 10 ohms was the value I saw but it said that could be tweaked to suit your needs.
Here is a link: https://www.electrosmash.com/little-gem-analysis#link3
Thanks again for your help!
rayandkerry
Next
Users browsing this forum: knobToucher, nickthemen and 6 guests
