EHX - The Freeze
Re: Electro-Harmonix: The Freeze (Gut Shots for fun)
Postby Alex Frias » 18 Jul 2011, 01:10
azrael wrote:http://axiomdrift.com/freezeloop.htm
Effects loop mod!
Again? Is it a time/reality loop? LOL :slap:
Alex Frias
Have thanks: 14 times
Postby azrael » 18 Jul 2011, 07:44
i actually got really excited when i found the mod and forgot to read the topic and check if someone already posted it. I was going to delete my post...but no post editing, haha.
pretty dumb. :slap:
azrael
Has thanked: 33 times
Have thanks: 93 times
Postby Alex Frias » 18 Jul 2011, 14:28
No problem, welcome to the jungle!!! :horsey:
Alex Frias
Postby cpm » 18 Jul 2011, 22:46
this is a non-laching switg, isnt it?
i'd rather replace it with a soft-touch switch
cpm
Have thanks: 52 times
Postby Alex Frias » 20 Jul 2011, 20:21
Alex Frias
Postby Alex Frias » 05 Aug 2011, 18:46
I opened mine and ruined the MODE switch in the process... :slap:
If someone knows where I could find a similar one it would be great!
Anyway I discovered a messy situation: when disconnected the pot central leg, the frozen audio signal appears at both legs, the disconnected one and the other one. As I am in a rush can't investigate it any further.
Someone else also tried to do this mod (not the destruction)?
Alex Frias
Postby cpm » 22 Jun 2012, 22:14
i noticed the spring on the daughterboard is nor connected to anything... i'd guess it was the to ground the chasis, but doesn't seem so...
cpm
Postby p_wats » 17 Oct 2012, 16:47
Super old thread, but I figured I'd add my experience, as I just added an effects loop and expression pedal out for this bad boy. Here's a video demo:
Link
The suggestion of cutting the connection to the wiper of the level pot and adding the effects loop there didn't work for me. I ended up tracing the circuit and taking the send signal from R3 and returning it to the board where the wiper connected.
The expression pedal was a simple case of using a switching jack to break the connection to the on-board pot and sent it to the expression pedal instead.
The biggest issue I had was getting the guts out of the enclosure without breaking the toggle switch (it's really all crammed in there). Do so at your own risk!
p_wats
Have thanks: 3 times
Postby Ben N » 19 Oct 2012, 12:12
Nice. Any pix of the work in progress?
Ben N
Has thanked: 17 times
Have thanks: 13 times
Postby p_wats » 22 Oct 2012, 16:43
Ben N wrote:Nice. Any pix of the work in progress?
There's are a few picts here:
http://dogisblue.com/gear/diy-effects-ehx-freeze-with-effects-loop-and-expression-pedal/
p_wats
Postby Jurassic » 30 Oct 2012, 07:58
p_wats wrote:The biggest issue I had was getting the guts out of the enclosure without breaking the toggle switch (it's really all crammed in there). Do so at your own risk!
Yeah, that pcb is really hard to get out without breaking the toggle switch.. Here's my arcade button mod:
http://www.jurimusic.com/modding-the-el ... ix-freeze/
Jurassic
Postby Bernardduur » 30 Dec 2013, 00:33
Hey all!
I have a freeze in that does not switch to effects mode..... signal passes through just perfectly but alas, no effect. The former owner got the unit from the box and removed the LED.... maybe something went wrong there....
Any ideas? Schematics?
Bernardduur
Has thanked: 87 times
Have thanks: 489 times
Previous
Users browsing this forum: No registered users and 8 guests
