Boss RV-3 (or DD-2,3) High Cut Mod? Diagram, values?
Postby nihoneiga » 03 Jan 2011, 13:39
Hi guys, after two years of building my own pedals I've broken down a purchased a Boss RV-3 just to have some reverb on my board when gigging in Japan (you never know what kind of amp you'll encounter as they are provided by the venue here). I tried reverse engineer the Hermida reverb box that used "the brick" digital reverb but I failed miserably twice so I gave up and bought the Boss.
Anyway, I've listened to a number of samples of Boss RV-3 with a high cut switch mod and I love the option of switching between the two. I think it's a fairly simple procedure and would like to perform this on my new (used) pedal but can't find anything online but vague information about adding a cap and switch to the back of the of the feedback pot.
Could someone spell out for me how to perform the high-cut mod? Cap values, type of switch etc, and/or a diagram would be a godsend! I've been building some of my own pedals but still lack some fundamental logic of how things inherently go together in electronics so the clearer and more hand holding the explanation the better.
Many thanks, and happy new years!
nihoneiga
Re: Boss RV-3 (or DD-2,3) High Cut Mod? Diagram, values?
Postby kekke466 » 07 Jan 2012, 19:14
I'm trying to achieve the same mod.
After some research I've found out a way to cut the highs by placing a 0.1µF cap in the dry signal line (on the Balance potentiometer).
Because the other potentiometer function as encoders they cannot be used.
BUT, by adding the cap, the balance pot has volume loss on the dry signal, so I'm trying to figure out how to only affect the line of the repeats only.
Did you figure it out yet?
kekke466
Postby Dirk_Hendrik » 08 Jan 2012, 11:19
boss_rv3_delay_reverb.pdf
What you want to do is alter the filter curve of the filters built around Q7 and Q8.
Has thanked: 250 times
Have thanks: 1004 times
Postby Fredenando » 08 Jan 2012, 15:03
Fredenando
Has thanked: 474 times
Have thanks: 93 times
Postby kekke466 » 09 Jan 2012, 00:16
Okay, I found it!
I put a 47nF cap over the two outer lugs of the balance pot, one is ground and the other is the one from the repeats.
Works great! The pedal sounds so much better without those bright repeats, incredible!
kekke466
Postby spacelordmother » 14 Feb 2017, 00:27
I went into my RV-3 to do this mod and am a bit stumped by the balance pot:
I have been looking at the board (VR 2/2) in the posted schematic and can't seem to figure out which are pins 1 and 3. Would love to learn how to decipher this riddle!
(the board looked that way when I opened it up...)
spacelordmother
Postby spacelordmother » 17 Feb 2017, 23:13
For anyone else who stumbles upon this page -- In the image above, bottom left lug on the pot connected to ground rolls off highs on the wet signal, 3rd from left on the top if you want to roll off on the dry. I tried a few different cap values, but .047uf did seem to be the most usable, but enough of a change to warrant the mod and a switch to turn it on and off. :thumbsup
spacelordmother
Return to Pimp-My-Cheap-Pedal
