I have two of these. I have already done some mods to one.
These are two beat up little boosts pedals that I have owned since the 9th grade.
I have heard you can make them like a klon type boost, I have heard you can make them klon boost killers. I have heard you can make them really hi-fi and and clean and crisp. I have heard that the creation audio labs mk4.23 is just a modified microamp.
I am bored and want to try everything. As is they are noisy and kind of bland sounding. Decent, but bland.
Here is the schematic
http://www.freeinfosociety.com/electron ... php?id=568
Help Me Pimp my Microamp
- analogguru
If you own two originals, maybe you could be so kind and control if the "Gain"-poti is really 500k reverse logarithmic ?
What I would change as the first step would be:
Socket the IC and replace the TL 061 by a TL071 for less noise.
Replace the 22M (R1) with a 2M2.
Replace the 10M (R2) with a 1M.
Now you can use other op-amp (non-Fet, e.g. 741, 5534) too....
