Blend control for a Dynacomp/Ross Compressor
drmathprog
Post by drmathprog »
I'd like to build a Dynacomp/Ross circuit with a blend feature like Barber's compressor has. Can anyone point me to a circuit fragment or idea that will get me started? Barber's design seems to have a pot that goes from "all Direct, no compress" at one extreme to "pure compress, no direct" at the other, with all points in between as Billy G. would put it.
Thanks in advance.
Alex C
Post by Alex C »
The Voodoo Lab Sparkle Drive is a Tube Screamer with a blendable clean control. You could implement this or a similar clean blend with a compressor circuit. It looks like the clean is just obtained via a unity-gain opamp buffer where the signal enters the noninverting input of the clipping-stage opamp, and blended with the TS output with a dual pot.
(direct link)
I had a Sparkle Drive, and it went from all clean to all drive, so it seems like this blend setup would give you the two extremes that you want.
-Alex
Greg
Completed builds: LOTS..
Has thanked: 65 times
Been thanked: 164 times
Post by Greg »
Or you could sneak a peak at the online schematic for BYOC's Ross comp.. with Blend control.
It's all there for you.
drmathprog
Thanks; I did look at BYOC's online schematic, but it is pretty complicated and a but over my head.
minor7th
Post by minor7th »
Sorry for the late entry. Just flown in from a weekend of sub-tropical seaside gigs... Mmmmm.... [smilie=drink.gif]
If I read your request correctly, you are probably looking for these:
Ross Mixer layout by MarkM. You can pick up his various Ross/Dyna/Etc layouts too.
Ross/Dyna Blend Mod by the Processorsaurus
Also look in The Other Forum for a thread or two on it.
m7 [smilie=vibes.gif]
drmathprog
Great! That's very much what I'm looking for. Thanks!
The "Other Forum"?
minor7th
Post by minor7th »
drmathprog wrote:Great! That's very much what I'm looking for. Thanks!
The "Other Forum"?
diystompboxes.
(Long story. I'm not the one to fill you in! :)
