Joyo - Extreme Metal
Postby Threetoe » 22 Sep 2012, 00:39
Hey guys I'm looking to mod my joyo extreme metal so I can either add a seperate knob for the boost channel to controll volume and treble boost seperetly, or take away some treble or add bass. It's almost unusable as is. Anyone found a solution yet?
Jesse.
Threetoe
Re: Joyo extreme metal mod?
Postby Threetoe » 23 Sep 2012, 00:26
To clarify, I've never modded a pedal so I'm realy not sure what I'm doing or anything. I'd really like to get into pedal modding, I do have experience with soldering so any tips or points would be great. Would something like adding a resistor to the boost to add bass or something work?
Threetoe
Postby greenskull » 11 Oct 2012, 02:27
Sorry to see you have not had a response, but a schematic will be needed before you can get help, I think. Maybe at least board shots will get someone to chime in.
fuck smooth tone, fuck eric johnson - Seiche
greenskull
Has thanked: 37 times
Have thanks: 9 times
Postby marmaliser » 11 Oct 2012, 10:14
marmaliser
Has thanked: 53 times
Have thanks: 46 times
Postby JiM » 17 Oct 2012, 13:59
One side of the board is missing, nothing can be traced out of this !
JiM
Has thanked: 30 times
Have thanks: 37 times
Postby GizmoGardens » 23 Oct 2012, 21:28
Threetoe wrote:To clarify, I've never modded a pedal so I'm realy not sure what I'm doing or anything. I'd really like to get into pedal modding, I do have experience with soldering so any tips or points would be great. Would something like adding a resistor to the boost to add bass or something work?
If you've never modded a pedal, this may not be the one to start with. How comfortable are you with soldering SMT components? It's not fun and it's pretty easy to ruin whatever it is that you're working on. Try starting with an Ibanez TS5. You can buy one for $30 bucks, or so, they don't have a lot of components, and there's a lot of documentation on modding them. That's what I started with.
GizmoGardens
Postby snabero666 » 15 Dec 2013, 05:54
Good day forumite,
Here's a mod that you can apply to extreme metal with great result. Extreme has the same distortion circuit with metal muff and boss mt2.So I try the mt2 no nasal sound mod. removing two capacitors C2 and C10 using cutter or nail puller.
here is some sound sample http://www.youtube.com/watch?v=gKFLoKe1PBE
http://www.youtube.com/watch?v=qnHR3HLCsVg
the distortion will be dynamic and its more marshall with great bass. the boost now makes the mid more pronounce or making it metal but still dynamic. This mod can be used at metal muff.
snabero666
Have thanks: 2 times
joyo extreme metal better usable tone
Postby snabero666 » 15 Dec 2013, 15:19
Good day forumite,
snabero666
Re: joyo extreme metal better usable tone
Postby tcpoint » 13 Mar 2014, 06:00
The technique that I use to remove smd resistors and capacitors is to melt the solder on side of the component and then melt the other side really fast and then alternate heat on both sides rather quickly. It doesn't take long for the component to come off. Then I use desoldering braid to clean up the remain solder.
tcpoint
Re: Joyo - Extreme Metal
Postby servantadvocate » 08 Sep 2017, 12:30
I am completely new to modding pedals. I attempted to do this and now the pedal doesn't turn on. did I screw something up? nothing is removed but these two capacitors. any tips on fixing this? and yes I had the pedal hooked up to a guitar and amp when trying this. other joyo pedal I have powered on.
servantadvocate
Return to Pimp-My-Cheap-Pedal
