Mooer Trelicopter volume increase
Postby sjturbo » 19 Jan 2014, 02:06
When I first got the Trelicopter I really liked it. I now realize that it has a volume increase when engaged (I would prefer no increase or decrease). Does any one know how to manipulate the volume by changing any components?
sjturbo
Re: Mooer Trelicopter volume increase
Postby biliousfrog » 21 Jan 2014, 11:02
I would suspect that it is entirely SMD so modding it won't be easy/worth the hassle. The volume increase is probably to counteract the perceived volume drop that tremolo pedals give - if you haven't already, make sure to test it in a full band situation to see whether the increase is noticeable with all the other sounds and frequencies bouncing around, usually a tremolo pedal at unity gain will sound much quieter.
biliousfrog
Have thanks: 10 times
Postby sjturbo » 21 Jan 2014, 20:04
Thanks for the reply! It is likely smd and I knew it was a long shot. That's what I get for being miserly.
sjturbo
Postby modman » 30 Dec 2017, 01:00
sjturbo wrote:Thanks for the reply! It is likely smd and I knew it was a long shot. That's what I get for being miserly.
Could you please at least open it up and share some gutshots to get at least an idea of what's going on?
It's likely a clone of an existing circuit.
Has thanked: 3280 times
Have thanks: 611 times
Return to Pimp-My-Cheap-Pedal
