Sorry for the cryptic title,
I've an MXR Phase 90 and I've a strong desire to replace the 3.5mm PCB mounted jack with a 2.1mm jack. I'd like to replace it with a barrel jack mounted off the board but I don't think there's space.
Is it possible to Macguyver a standard 2.1mm pcb jack to fit in the same space? Maybe by bending the leg or snapping one off - so the mounting is reasonably strong but the power in is standardised.
I don't really like extra adaptors on my daisy chains....
Thanks for reading, hope it's clear what I'm asking
3.5mm neg tip to 2.1mm neg centre pcb jack replacement.
- lolbou
http://www.banzaimusic.com/Lumberg-PSU-1614-09.html
I would try these, although they don't lift the battery off when DC jack is plugged in... ?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
