ProCo Roadkill / Brat
Postby Oqsy » 02 Sep 2017, 23:53
I have 2 questions.
1. Which tabs on this jack should be attached to which traces on the output on the right side of the pcb? Old output jack was cracked. I have attached photos of both sides of PCB (component side is L-R inverted). The schematic I've found for this pedal makes no sense, and I don't have the best setup for testing as I go (no amplifier near bench). The old jack was a 6 pin pcb mount plastic thing, but I'd rather wire in the jack i already have.
2. I have read many places that the Brat/Roadkill is very similar to a Rat except the feedback loop of 4 diodes (top right I believe). Could a pot be inserted before these diodes to allow you to "blend" in or out the feedback loop all the way to zero, giving you a gain quality from Rat -> Roadkill? I know I can drill the hole and add in the needed part(s), but I am not sure I am up to snuff on my theory to predict the behavior of this change.
Thanks in advance to everyone!
Oqsy
Re: ProCo Roadkill / Brat
Postby Oqsy » 03 Sep 2017, 00:36
Zoomed in and traced the area for possible potentiometer (or switch) insertion.
Oqsy
Postby Oqsy » 03 Sep 2017, 03:04
Can't find the edit button on this forum. Scratch #1 off the list. It was a tight fit but I got the jack replaced with the much nicer handwired piece and realized I was misreading where the black wire to - was soldered in, realized which trace led directly to it and have it up and running.
#2 is still something I'd like to pursue if anyone knows how feedback "blend" circuits work.
Thanks and sorry about bugging the board about the goof spotting the output jack ground trace.
Oqsy
Return to Pimp-My-Cheap-Pedal
Users browsing this forum: El Burro and 2 guests
