Boss DS-1 issues after Keeley mod
Postby segoy » 28 Jan 2018, 13:18
Hi!
I modded my DS-1 following the instructions available here: http://www.instructables.com/id/Modify-Your-Boss-DS-1/
All seems to work fine but the distortion knob causes some issues.
It does what it's supposed to do as long as you don't krank it higher than 2 o'clock.
After that it works like some kind of threshold and attenuates lower signal passing through only stronger signal.
With lower signals it just farts. :)
Anybody encountered this issue? Any ideas how to make it work fine through the whole range?
segoy
Re: Boss DS-1 issues after Keeley mod
Postby segoy » 30 Jan 2018, 21:39
I checked everything again and found the source of my issue.
I used tantalum caps having no idea that they have polarization! Once I changed them to classic caps everything works fine!
cheers!
segoy
Return to Pimp-My-Cheap-Pedal
