Is there a ts9 mod like this?
Postby Sirshredalot » 10 Feb 2018, 00:30
Hello all, first post
Right to the point.
Is there a way to mod a ts9 so that no clean signal comes through?
Please and thank you
God bless
Shred
Sirshredalot
Re: Is there a ts9 mod like this?
Postby phatt » 10 Feb 2018, 01:29
Yep,, just turn the gain up full. :thumbsup
Phil.
phatt
Have thanks: 236 times
Postby Dirk_Hendrik » 10 Feb 2018, 10:44
Like Phatt says.
Or, essentially, even easier. Just keep it stock. There is no mixing stage or similar where dirty and clean are mixed or something. Therefore, when engaged, all signal is dirty. It's just not dirty enough for your taste I'm afraid.
Has thanked: 250 times
Have thanks: 1001 times
Postby paulc » 11 Feb 2018, 17:03
One thing I like to do to them is to convert the clipping opamp into an inverting stage. This will cut the clean bleed way back. It can be a little tricky to do, but pretty easy in the ts10 and takes just minutes in the EH East River. A little more saturation, compression, and less "clutter" in the low end. A slight loss in volume and attack because the clean transients are not coming through. It's easy to get the volume back with a tweak to the diode clamps.
paulc
Have thanks: 49 times
Postby Sirshredalot » 14 Feb 2018, 10:34
Thanks for all the replies.
Im a rookie at pedal mods, do you have a schematic or intructions for that mod?
I can solder.
God bless
Shred
Sirshredalot
Postby paulc » 14 Feb 2018, 20:51
Sirshredalot wrote:Thanks for all the replies.
I can solder.
God bless
Shred
I can't get a pic to post... :scratch:
paulc
Postby bugg » 17 Feb 2018, 02:37
I prefer to replace the clipping diodes with 3mm red LEDs....
bugg
Has thanked: 30 times
Have thanks: 214 times
Return to Pimp-My-Cheap-Pedal
