MOD IDEA: would this make negative feedback of boss BF-2?
Postby scoop » 08 Jul 2018, 01:53
this is the full schematic
I figure this is the last opamp (buffer?) before the delay line goes to the resonance knob.
If I simply find a way to swap pins 2 and 3 of IC2 would that make the signal inverse?
Thanks for any advice!
scoop
Re: MOD IDEA: would this make negative feedback of boss BF-2
Postby phatt » 08 Jul 2018, 03:04
Short answer,, NO.
longer answer; Quick fix mods without a deep understanding of how something works will just lead to tears.
Messing with pcbs is the fastest way to destroy a good working pedal.
If you want to fiddle with this circuit buy the parts and breadboard your dreams. :wink:
Phil.
For this message the author phatt has received thanks:
modman (08 Jul 2018, 19:50)
phatt
Have thanks: 266 times
Postby scoop » 08 Jul 2018, 14:51
well luckily there is a bit of room in the BF-2, I could possibly fit a daughter board in that inverts in the path of the resonance
scoop
Postby marshmellow » 17 Jul 2018, 20:58
In addition to what Phil said: you can't change the polarity of the signal at that point. It would upset the phase relation of the mixer in front of the BBD, as well as the mixer of clean signal and effect signal at the output.
marshmellow
Have thanks: 122 times
Return to Pimp-My-Cheap-Pedal
Users browsing this forum: Bing [Bot], Steeler [Crawler] and 1 guest
