Arion sch-z too much bass
Postby bm13 » 11 Aug 2018, 08:35
Hey,
I recently bought a Arion Sch-z and love that pedal since then!!
The only problem is that it adds a lot of bass to the mix and I can't get it out with the Tone knob.
'Found the schematic here on the board:
download/file.php?id=13076&mode=view
Does somebody have ideas on how to get rid off that bass boost??
Or are there already some mods for that problem?
Many thanks,
bm13
bm13
Have thanks: 5 times
Re: Arion sch-z too much bass
Postby phatt » 11 Aug 2018, 09:58
Yes mine had the same problem, way too much bass. :roll:
It's been a long time but look at VR3 (Tone pot)
I can't recall exacts but I'm fairly sure I just lowered the value of C19 or C20,, or maybe it was both?
If you want exact values I used you will have to wait till I pull the back off as I'm using the pedal for the next few days.
Phil.
phatt
Have thanks: 266 times
Postby bm13 » 12 Aug 2018, 13:59
Thanks phatt, that would be great!!
bm13
Postby phatt » 15 Aug 2018, 06:35
Hi BM,,My Brain can't remember well these days :oops:
OK, I've pulled the back off and discovered that all you have to do is change C18 (470nF marked .47u) to 33nF. that's it, :thumbsup
,I just used a green cap.
C18 is down the bottom of board while C18 & C19 are up the top under the tone pot IC1.
I've been happy with the result and works fine with my gear.
Phil.
phatt
Postby bm13 » 16 Aug 2018, 08:46
Many thanks!!
I'll give it a try
bm13
Postby phatt » 23 Aug 2018, 14:01
This worked for my setup just fine, but let us know if that works for you so that others here can cross reference the outcome as everyone's rig is a different. :thumbsup
Phil.
phatt
Postby bm13 » 25 Aug 2018, 13:51
I changed C18 to 47nF.
33nF was a little bit too much for my taste.
...maybe something in between would be an even better fit for my rig.
But now I'm way more happy with the chorus!!! :D
bm13
Return to Pimp-My-Cheap-Pedal
