EMA - Chorus EP-16
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
Some time ago I bought this chorus pedal for 8 EUR -- case is plastic, but the jacks are chassis mounted. It says 'Made in Korea'
http://filters.muziq.be/model/ema/ep18
The outer case says EP18, but the pcb is marked EP16. ICs are M3223L (thin one) M5218AL (two thicker ones). BBDs didn't come from Hongkongsuperseller ... this time
Here some guts:
Here some guts:
- EMA Chorus EP16
- DSCN4385.jpg (272.65 KiB) Viewed 1384 times
- EMA Chorus EP16
- DSCN4386.jpg (286.59 KiB) Viewed 1381 times
- DiscoFreq
That's strange because the EP-16 is the distortion and this doesn't look like a multi-function board as with the small Coron pedals (same PCB for several effects).
Interesting, thanks
Interesting, thanks
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
- analogguru
The BBD and clock driver are original matsushita - probably from 1982. The other components used appear also from the 80´s. What else is written on the chips and on the electrolytics ?
- modman
- a d m i n
Electrolytics are either DKE, DEC or Han Sung.
All three ICs have the Mitsubishi logo. Two of them read M5218AL 252028 the other one (thinnest) M5223L 304003
Transistors: (top to bottom, left to right, except TR5 is under TR4
TR 1-2 = K 3F C3200 GR --> BC320?
TR 3 = K 3G K30A GR --> 2SK30A
TR 4-8 = C945 YC311 --> BC945
Discofreq,
After knowing my aunt Suzanne for 25 years, I was shocked to find out that she's really called Yvonne. But then again I never asked her for gut shots
I'm curious what's written on the distortion pcb - but I don't think it influences the sound that much.
Do you own any of other EMA pedals or their equivalents?
Discofreq,
- analogguru
Not any numbers on them ? anyway the unit appears to have been produced in early 1983....Electrolytics are either DKE, DEC or Han Sung.
= 2SC 3200-GRTR 1-2 = K 3F C3200 GR --> BC320?
= 2SC 945-YTR 3 = K 3G K30A GR --> 2SK30A
- modman
- a d m i n
So the 23/28 on the BBDs is a date code?analogguru wrote:Not any numbers on them ? anyway the unit appears to have been produced in early 1983....Electrolytics are either DKE, DEC or Han Sung.
19(M) on the Han Sungs, the other only have temperature ratings on them..
- DiscoFreq
Lol
I know Seifukusha from HC has the delay (possibly there are gutshots on HC somewhere?)
No, not yetmodman wrote:Do you own any of other EMA pedals or their equivalents?
Sorry for posting on such an old topic but I don't have found any other one about this pedal over the Internet...
A friend gave me this old chorus pedal yesterday as it was out of order.
Actually, there was a broken bypass wire, and except concerning scratchy pots, everything seems fully functionnal.
But some details seem weird:
Turning the Rate pot doesn't seem to change anything or a little Still a slow chorus, there's no way to obtain a vibrato-like chorus...
I had a look at the LFO but as I thought this pedal was a Boss CE-? clone or quite similar, it's rather different. At least concerning the LFO...
The other thing is that even with the Depth pot maxed, effect is not so big, just a sweet chorus. But when the pot scratches, a sort of "boost" appears in the effect just for an instant.
I've shorted it to see what happens: nothing...
Any idea?
Or better: any schematic?
I've made a layout with the PCB picture above, in order to trace a schematic. But it's such a mess...
Any idea?
- tube-exorcist
A Boss CH-1 schematic should lead you to success.CheapChip wrote: Any idea?
