Biyang Tremolo TR8 Volume Mod
Postby onsonsons » 21 Apr 2010, 18:06
the biyang tremolo or the fame stutterer tremolo is equivalent to the boss tr-2 but has got true bypass instead of buffered output. too bad the volume of the effect is not loud enough.
no problem, just replace R6 (10K) with a lower value or solder on the backside of the pcb another resistor parallel to R6. i used a 5,6K resistor parallel to R6. now the pedal is much more useable.
have fun. you can't go wrong with this pedal. :secret: BEST BANG FOR BUCKS!!
onsonsons
Re: Biyang Tremolo TR8 Volume Mod
Postby sinner » 21 Apr 2010, 21:19
Good to know :) Thank you :thumbsup
Has thanked: 1239 times
Have thanks: 1098 times
Postby iconica » 01 Dec 2011, 06:30
The GFS has the Same problem...Better built than Biyang though...You can apply the same mod to GFS Tremolo too...The only withdrawal is the micro components on it
iconica
Postby jpistolas » 27 Apr 2015, 20:18
I have the newer Biyang TR-12 "Classic Series" which aside of cosmetics seems to be the exact same pedal. Could I simply replace the 10k resistor with a 10k trimpot? If so what type pot would be best to use. I would want to turn the pot clockwise for more volume.
Aside of the perceived volume drop this is fantastic pedal, especially for it's stupid cheap price.
Also, is there an easy way to preform the Boss TR-2 Led rate mod to this pedal with the existing power Led. Granted, as bright as it is it could cause seizures.
jpistolas
Postby jpistolas » 02 Jun 2015, 02:19
Just curious but would removing the resistor make the pedal too loud and would it need a jumper?
jpistolas
Postby edwinbass » 21 May 2017, 14:59
Does anybody have a schematic for this Biyang TR-8 ?
edwinbass
Return to Pimp-My-Cheap-Pedal
