PCB Clearance VH4, Wampler Faux and Plexi,RM Voodoo, BassDI
Postby brejna » 08 Nov 2017, 17:39
Hi fellas, I have pcb clearance..
I am offering :
Warhead (VH4 Diezel) 8$ (2 left) I omitted 12v regulator from power input. Also you can find some oscillations on gain settings between 7-10, but when you put buffer in front everything is silent.
Build docs https://www.dropbox.com/s/docb80glowb79 ... d.pdf?dl=0
Arburat (Wampler faux echo) with adaptation for Taprecise from Marshall Arts 7$ (9 left)
Build docs https://www.dropbox.com/s/2xz3xq41kkg15 ... t.pdf?dl=0
Plexi Drive 1590a SMD with fet switching 5$ (5 left)
Build docs to come..
VoodooVibe pcb - 15$ (6 left)
Build docs https://www.dropbox.com/s/xv1kguunn6bbe ... 5.pdf?dl=0
Build Report http://www.madbeanpedals.com/forum/inde ... #msg213211
Bass Preamp DI with classic boss switching (fet) 8$ (4 left)
Build docs https://www.dropbox.com/s/y4d5ua4t1ju0d ... 1.pdf?dl=0
Carl Martin based compressor from UK-electronics partially populated 12$
Build docs http://www.uk-electronic.de/Download/Th ... 20V1.4.pdf
Fulltone Plimsoul from bugg fully working with all onboard parts 20$. You can expect little bit of oscillation on higher gain settings..
Also I have Boomerang wah pcbs if someone is interested..
Boomerang Wah 8$ (left)
Build docs https://www.dropbox.com/s/a9x6yyqv4td77 ... g.pdf?dl=0
My PayPal is branekascel@gmail.com
Shipping for 3 pcbs is 3,5$
Cheers
Brane
brejna
Has thanked: 65 times
Have thanks: 53 times
Re: PCB Clearance VH4, Wampler Faux and Plexi,RM Voodoo, Bas
Postby brejna » 12 Nov 2017, 17:45
VH4 are sold!
brejna
Return to Parts Sourcing & Trading
