Original MXR Dyna comp boards for sale
- the3secondrule
mine also arrived today.
Cheers!
Cheers!
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
Some of the numbers on the schematic are really hard to read, anyone got a clearer one? Or a BOM?
- plesur
- Degoop Doctor
There's a nice schem in this thread:
viewtopic.php?f=1&t=10580&p=115820#p114674
Not sure if it's exactly right for these boards though, I'm waiting for mine to arrive.
That schematic is redrawn from the factory one I provide!!!plesur wrote:There's a nice schem in this thread:
Steve Did a great job on that!!
Chris
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
Chris, I'm still waiting for paypal invoice
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
fatt-one,
I used to own an original MXR Dynacomp,till it got stolen from me,and I have been wanting to build one,do you still have any PCBs left?,i do happen to have some LM3080 ICs,but they are the square 8-pin plastic types,which I am assuming should work fine....
if you do have some PCBs left,how much are they?.....
- jrod
I used this one from Small Bear and it fit perfectly: http://www.smallbearelec.com/Detail.bok?no=779plesur wrote:Does anyone know what kind the 2k trimpot that fits in the three larger holes above the IC is?
- DrNomis
You could probbably get away with using a 2k horizontal mount trimpot...
- sinner
Boards came in yesterday! Highly recommended, will buy again soon Thanks a lot Chris
- sinner
perhaps silly question - I have both CA3080A and CA3080H IC's, which one is the correct one in Dynacomp? What's the difference?
- PokeyPete
A little time has passed since you asked this question and I'm sure you have found your answer by now.sinner wrote:perhaps silly question - I have both CA3080A and CA3080H IC's, which one is the correct one in Dynacomp? What's the difference?
I have done a small amount of research on the different versions and have determined the following:
Information was compiled from both Intersil and Harris data sheets.
There are two main versions.....CA3080 and CA3080A.....the CA3080A has a wider temperature range
and better transconductance specs. Most other specs are practically the same. I'd consider it a military version.
CA3080............Metal Can
CA3080A..........Metal Can
CA3080E..........8 Pin Plastic DIP
CA3080AE........8 Pin Plastic DIP
Sinner, I couldn't find any information on your CA3080H. Back in the '70s I was managing an electronics store.
As I recall the H suffix referred to an IC in a TO5 can. Based on this information it appears that you have metal
can versions of both types. Who is the manufacturer of the CA3080H? (The 'H' suffix was common way back when,
and could have been used by both Intersil and Harris but didn't show up on more modern data sheets.)
–Hunter S. Thompson
–Hunter S. Thompson
- sinner
Skinner?fatt-one wrote:Sorry skinner!!! so late ....only what's listed!!!sinner wrote:Kiss for the Blue Box PCB
