Russian Germanium Transistors on Ebay
- RnFR
installing a transistor backwards is a lot different than low gain. regardless, I doubt the hoof has transistors with gains of 300. I think he uses 2n1306? which are the npn equivalent of 2n1307s of which I have many. they avg around 120, which I think should be fine. if it's not 2n1306, just look up the datasheet(but don't go by the highest rating listed, Ge transistors rarely reach that high).
- Hides-His-Eyes
A backwards transistor has an hFe of several, not of 100+.azrael wrote:it was something post by mattpas of Stomp Underfoot here. The guy knows his muffs, so i just took his word on it.
I do know that low hFe can significantly change a Muff's tone for the worse. I once worked on a Green Muff that had a transistor that somehow conducted backwards, and had been installed backwards (the pinout could have been reverse, but it's hard to tell since they were all unmarked. Regardless, I sgtill believe it had low hFe.). Didn't sound quite right until I replaced the transistor.
On the previous discussion; supposing I have determined that a transistor has sufficient gain DESPITE the leakage; is the leakage a disadvantage still?
- DrNomis
- Has thanked: 98 times
- Been thanked: 278 times
Hides-His-Eyes wrote:A backwards transistor has an hFe of several, not of 100+.azrael wrote:it was something post by mattpas of Stomp Underfoot here. The guy knows his muffs, so i just took his word on it.
I think so, since the leakage can lead to bias-instability and then a condition called Thermal-Runaway, this is where the transistor heats up, current gain goes up as a consequence,causing more current flow, more current flowing means more heat generated, etc, etc, etc........ in a vicious-circle, ending in the transistor's destruction......
- jrod
That interesting stuff Greg!Greg_G wrote:Thoughts on zero-leakage Germaniums:
I've always wondered how these zero leakage Germaniums came to be.
The leakage in Germanium is inherent in the material, and is a major reason it's been mostly replaced with silicon in electronics (the other is ability to handle heat).
Germanium in many aspects has better properties than Silicon, BUT.. it leaks about 1000 times more than silicon, and you can't overcome that with better manufacturing processes or whatever.
Earlier I questioned whether they were really Germanium if they measured zero leak, and IvIark pointed out that if the Vf measures as Germanium, then it's Germanium.. hard to argue with.
I did some searching and reading over the week-end, and I now suspect that these zero leak transistors are not pure Germanium, but a hybrid device.
Apparently Germaniums can be made with leakage similar to a Silicon transistor (or diode), by insulating the transistor gate with a layer of Silicon or other materials like Zirconium Oxide.
This affects nothing as far as their use if they sound good, I just thought it was interesting.
I have some germanium devices that measure 0 leakage with my Peak Atlas, however, when using the old RG Keen method I will actually measure some leakage. Usually low, but it shows there is leakage on the meter.
It may be that the Peak Atlas shows 0 leakage when there really is some there, though low.
- DrNomis
jrod wrote:That interesting stuff Greg!Greg_G wrote:Thoughts on zero-leakage Germaniums:
It could be that the leakage is below the threshold of what the Peak Atlas can detect, yet it's high enough to be detected by RG Keen's method.....
- azrael
Hm, alright, maybe I'll aim for something lower then.RnFR wrote:installing a transistor backwards is a lot different than low gain. regardless, I doubt the hoof has transistors with gains of 300. I think he uses 2n1306? which are the npn equivalent of 2n1307s of which I have many. they avg around 120, which I think should be fine. if it's not 2n1306, just look up the datasheet(but don't go by the highest rating listed, Ge transistors rarely reach that high).
EDIT: I still feel like it would be hard to get the bias up to around 4.5V. Maybe if I use a diode in place of the emitter resistor? Like a 1N4001?
- Hides-His-Eyes
soviet germanium is so plentiful and cheap, just order a few batches of ten and try them out
- Hides-His-Eyes
buahahahaha
I don't think "stands out in a mix" is really the thing the muff is known for
- Seiche
I know, wouldn't germanium makes this even worse? they sound smoother in my ffHides-His-Eyes wrote:buahahahaha
- Hides-His-Eyes
I don't think it would matter to be honest, the lack of mids would make masses more difference
"smoothness" is the kind of thing you can just turn up the gain or volume for, isn't it?
- RnFR
the clipping usually comes from diodes in a muff. the transistors never clip. in the hoof there are LEDs, so you might get some clipping from the transistors. all of the circuits clip in different ways.
- DrNomis
And remember that there are two sets of clipping diodes in a Big Muff, and they're silicon, I've scoped a Big Muff before and the clipping is very sharp, the waveform is almost a perfect square-wave except that there is a notch next to the leftmost corner, this is caused by a notch in the tone controls frequency response at about 1.4Khz.....
- LucifersTrip
- my favorite amplifier: Companion Psychedelic Machine
- Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
- Has thanked: 19 times
- Been thanked: 71 times
- Contact:
That depends on how you set the amp. I turned the treble way up and the bass down and got a thin waspy fuzz...Hides-His-Eyes wrote:buahahahaha
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
RnFR wrote:I just got about 50 GT309Es off of ebay, and I thought I'd post the results. the vast majority hovered crazily close to 80Hfe. there were only about 10 that were outside of about +/-10%. highest around 100, lowest around 60. lots right between 78 and 82. extremely tight tolerances. no leakage throughout, and one dud. these things are sounding crazy awesome in some fuzz face circuits I've been working on. nice breakup, tons of gain, and excellent clean up characteristics. one thing I should mention is the size of these guys- they're tiny! they would be considered small for a Si tranny, much less Ge. they look small versions of the GT313- little flying saucers. if you want to see them in use, you can check out the H-Fuzz on my blog. also, the leads are extremely thin- the thinnest I've ever seen on any transistor, so it would definitely be a good idea to prop them up with some insulation, and a heatsink would be advisable when soldering. I think I actually cooked one of these little guys when desoldering one. regardless, great transistors at a great price.
My order arrived yesterday. Odd pinout, but apart of this I couldn't be more happy with them )))) From whole lot - no leakage at all, gain ranges 65-110 - PERFECT! Those ARE tinny, lay down perfect on IC vero. I'll draw some layouts specially with them in mind later today. Thanks for the info. I'll get lot more for sure.
- DeanM
Gregg, you might have better look finding info by using the russian lettering, ГТ309Е. I had a quick look using that, its time consuming tho cos ya have to google it, check out links and then translate them back to english with google translate.Greg_G wrote:Thoughts on zero-leakage Germaniums:
But one site said this
the translation is a bit messy but it says Germanium Alloy. With a little more digging it might be possible to find out what that alloy is exactly. I added words like parameters and specifications to the search to try narrow it down.Транзисторы германиевые лиффузионпо-сплавиые р-п-р усилительные высокочастотные мало.мощные.
GOOGLE translation: Transistors Germanium alloys liffuzionpo-p-p-p amplifying high enough. powerful.
- IvIark
Germanium wouldn't make a good semiconductor without the impurities added by doping, so that may just be a loose translation.
- RnFR
sinner wrote:RnFR wrote:I just got about 50 GT309Es off of ebay, and I thought I'd post the results. the vast majority hovered crazily close to 80Hfe. there were only about 10 that were outside of about +/-10%. highest around 100, lowest around 60. lots right between 78 and 82. extremely tight tolerances. no leakage throughout, and one dud. these things are sounding crazy awesome in some fuzz face circuits I've been working on. nice breakup, tons of gain, and excellent clean up characteristics. one thing I should mention is the size of these guys- they're tiny! they would be considered small for a Si tranny, much less Ge. they look small versions of the GT313- little flying saucers. if you want to see them in use, you can check out the H-Fuzz on my blog. also, the leads are extremely thin- the thinnest I've ever seen on any transistor, so it would definitely be a good idea to prop them up with some insulation, and a heatsink would be advisable when soldering. I think I actually cooked one of these little guys when desoldering one. regardless, great transistors at a great price.
nice ain't they? i'm very happy with mine as well. try em in a fuzz face. or better yet, try the H-Fuzz!
http://apocalypseaudio.blogspot.com/2011/01/h-fuzz.html
