Hi all,
Does anyone know of a source for a replacement switch like this:
It's from a Yamaha SG3000S tone pot and is used for coil-tapping. I have a complete replacement pot/switch that I scored from Martyn Booth but I thought I'd try and find a replacement switch so I've got a spare.
Any suggestions?
R.
push-push switch for Yamaha SG
- robinbowes
- Lucifer
Rapid Electronics do some push switches in a similar format which should fit onto that particular mounting bracket. The ones I looked at quickly were longer than what you’ve shown, but you should be able to cut them down with a junior hacksaw.
Failing that, take a few old TVs apart - you can often find that type of switch in there.
Good luck.
Good luck.
- robinbowes
Cheers, I'll take a look.
R.
R.
