1/4" Lumberg-type jacks on ebay?
- zedsnotdead
Hi!
do you know where I can find these type of input/output 1/4" jacks on ebay cheap? (I mean, asian made...) Much appreciated. Thanks a lot!!
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
- zedsnotdead
Thank you! Not so cheap... I was thinking of llumberg-asian-made, not lumberg original
- dai h.
those look like "Marushin"(Japan) :
http://www.ab.auone-net.jp/~est/pg-menu_e.htm
http://www.ab.auone-net.jp/~est/pdf/6.3.pdf
- danielzink
- Completed builds: Too many: www.danielzink.com
- Has thanked: 8 times
- Been thanked: 27 times
dai h. wrote:those look like "Marushin"(Japan) :
MJ159M
Kobiconn.
Mouser stopped carrying them as well....
161-MJ159M-EX
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
