Lithium Battery for TR505
Postby bob barcus » 19 Nov 2015, 23:53
My 1984 Boss TR505 was working fine.And then some of the sounds got distorted or do not work at all Snare and Hand clap..There is a Lithium battery in it..Does anyone know where I could get one? I do not know anything about these drum machines I guess you have to unsolder it from the back side..
bob barcus
Re: Lithium Battery for TR505
Postby Zokk » 20 Nov 2015, 10:17
Hi
before going further you should have a look at the service manual:
http://www.synthfool.com/docs/Roland/TR_Series/TR505/
You can find the 3V lithium with solder pin battery in many shops, for example:
https://syntaur.com/Items/4311.html
There a plenty on e-bay too which are a lot cheaper.
If the battery is really dead, you'll have to unsolder it, or cut the leads and fit a replacement battery with small wires (taking care of insulation of course).
I think it will reset the user saved patterns & sequences. You can avoid this while soldering the new battery in parallel with the old one, before removing it. So the RAM won't be cleaned.
There's a video where you see how to dismantle it:
Link
Good luck!
For this message the author Zokk has received thanks: 2
Blitz Krieg (23 Nov 2015, 09:07), modman (20 Nov 2015, 14:24)
Zokk
Has thanked: 173 times
Have thanks: 61 times
Postby snofla1900 » 20 Nov 2015, 14:16
Highly recommended procedure !
I performed this in my Xp 50 Keyboard and it worked great.
snofla1900
Has thanked: 87 times
Have thanks: 13 times
Postby nosamiam » 15 Dec 2015, 07:11
Zokk wrote:If the battery is really dead, you'll have to unsolder it, or cut the leads and fit a replacement battery with small wires (taking care of insulation of course).
Ingenious!! If I ever need to do another battery replacement--I really need to do my own TR-505--I'll keep this in mind. So simple!
nosamiam
Return to Parts Sourcing & Trading
Users browsing this forum: No registered users and 6 guests
