Joyo Sweet Baby footswitch replacement
Postby Mantaray14 » 16 Jun 2016, 15:51
I have Joyo Sweet Baby which I finally modded to my liking (added a 1meg pot for the gain and changed the smd chip to OP275). As soon as I had this thing dang-near perfect...the footswitch falls apart!
I ordered the new footswitch (Alpha), but I am very leary of delsoldering components on these joyo pedals and these switches are pcb mounted. I've had a few solder pads practically disinegrate while trying. I do have a solder sucker I plan on using...can can anyone share any experiences, tips or tricks for desoldering components on delicate pcbs or replacing pcb stomp switches on a joyo in general?
Any help would be appreciated!
Best regards,
Rick
Mantaray14
Re: Joyo Sweet Baby footswitch replacement
Postby Mantaray14 » 24 Jun 2016, 13:53
Just an update in case anyone else has this issue...I tried carefully getting the solder off the pads with a solder sucker and even a braid with flux. These suckers are in pretty tight and the pads are brittle. At that point I said screw it and broke out the dremel and just cut that sucker off. That seemed to do the trick!
Mantaray14
Postby mprall00 » 05 Aug 2017, 23:37
Mine broke too right after I modded it...
But I was lucky and got it to come out fine with a solder sucker. I have another cheapo Chinese switch in there now just like the one that it came with. It was only $0.99 on ebay. We'll see how long this one lasts. Next time I am going to drill a new hole in the battery compartment area or put in in a new enclosure so it can fit a real switch...
How did you get a real footswitch into the thing? There wasn't enough depth in the enclosure to get a real sized switch it there...
mprall00
Return to Parts Sourcing & Trading
