On-On-Off switches?
On-On-Off switches?
Postby eddie_bowers » 01 Apr 2017, 00:07
I realize mechanically having On-Off-On makes sense, but often it would be nicer to have On-On-Off for the user experience.
I can't find any mini switches that do this. Do they exist?
eddie_bowers
Re: On-On-Off switches?
Postby Dirk_Hendrik » 01 Apr 2017, 08:45
Perhaps in a pushbutton variant. For toggle switches this way of switching would be extremely complex from a mechanical construction point of view. Open a toggle switch, figure outn how it works and you'll see whay the on-off-on is easy but the on-on-off complex.
Has thanked: 250 times
Have thanks: 997 times
Postby Cub » 01 Apr 2017, 10:07
eddie_bowers wrote:I realize mechanically having On-Off-On makes sense, but often it would be nicer to have On-On-Off for the user experience.
You're right, on-on-off would often put the different sounds in a more logical sequence on the switch and make for a pedal that's more intuitive to dial in. Sadly, there's no mechanical on-on-off switch readily available, but you could take a DPDT on-on-on switch and wire it as you please.
That's how I did it in one of my fuzz builds. Beside the stock smoothness cap, I wanted to have an additional extra smooth sound of a cap with a higher value and the raspy sound of no smoothness cap at all. Preferably, in the logical sequence of raspy, stock and extra smooth. A DPDT on-on-on switch was the answer.
Cub
Has thanked: 66 times
Have thanks: 68 times
Postby eddie_bowers » 01 Apr 2017, 16:56
Using on-on-on never even occurred to me. Yeah I think that is the way to go. THANKS!
eddie_bowers
Postby Cub » 01 Apr 2017, 20:46
You're welcome ! Glad to be of help.
Cub
Return to Parts Sourcing & Trading
Users browsing this forum: No registered users and 6 guests
