Looking for replacement surface mount component
Postby soad11dude » 25 Apr 2017, 03:30
Gday all!
I bought an EH Silencer a few months ago (only $71 CAD... how could I say no). A few days ago, I decided to plug it in and play. In my haste to make face melting metal tones, I accidently plugged an 18VDC neg center pin power supply to the 2.1mm jack. Got some funky sounds and realized in horror what I had done. Opened it up. Smelled the magic smoke that had been released. I decided to not lose hope. With a 9V battery, the stomp box still functions. So the defector must be in the power supply section.
Upon further inspection, I found a diode that appears to be shorted. I'm assuming it's a zener diode, judging by the marking ZZ5 sitting next to it on the PCB. I tried finding an equivalent replacement part online and seemed to get nothing but Russian license plates.
TL;DR.... Can someone identify this diode?
soad11dude
Re: Looking for replacement surface mount component
Postby Intripped » 25 Apr 2017, 06:03
For this message the author Intripped has received thanks:
soad11dude (25 Apr 2017, 20:57)
Intripped
Has thanked: 568 times
Have thanks: 212 times
Postby soad11dude » 25 Apr 2017, 20:56
That would make sense. XE is indeed in the table. Reverse standoff of 12V and max breakdown voltage of 14.7V. 18VDC sounds like enough to make it go poof. I'll find one online and order it in. First time trying to solder surface mount components. Should be interesting.
Thank you very much!
soad11dude
Return to Parts Sourcing & Trading
Users browsing this forum: No registered users and 7 guests
