Difference in sound between different color LEDs
SpikeVelvet
Post by SpikeVelvet »
I'm a relative n00b at this and I am curious to know if there is a difference in sound between different colored LEDs when used as clipping diodes in an OD/Distortion circuit. I know the forward voltage ratings differ but does that affect the sound of the end product?
Moderator: I don't know if this is the right location to post this so please move as you see fit
Has thanked: 1675 times
Been thanked: 1360 times
Post by Manfred »
SpikeVelvet wrote:I'm a relative n00b at this and I am curious to know if there is a difference in sound between different colored LEDs when used as clipping diodes in an OD/Distortion circuit. I know the forward voltage ratings differ but does that affect the sound of the end product?
Have a look at this page, there you will find the LED Datasheets.
http://www.kingbright.com/content/listitem/psearch/56
Dependent on material the traced curves shows different shapes and treshold voltages.
The treshhold voltage determines the compression,
the curve shape determines the harmonics contain
which finally affects the sound sound spectrum.
SpikeVelvet
Thanks!!
