TL071 Substitutes
TL071 Substitutes
Postby Jim9guitars » 05 Jul 2017, 23:27
I've been out of the loop since the late 80's on this stuff, I'm having a hard time sourcing parts. Can a TL072 work as a direct substitute for a TL071? Failing that, does anyone know where I can order either one, preferably from a North American supplier(I live in Canada). As I gradually re-enter the DIY world I'm really amazed at how hard it is to find parts locally, and in some cases mail order. My current project is the simple buffer posted here, I want to see if I can work it into a multi effects unit I started building in the 80's. It centers around Craig Andertons "Tube Sound Fuzz" from his book "Electronic Projects For Musicians". I still have a working build of this but I can't find parts for most of the projects in this book now.
Jim9guitars
Re: TL071 Substitutes
Postby tonyharker » 06 Jul 2017, 09:38
A TL071 contains only one op-amp whereas a TL072 contains two. The pin outs are different look at the datasheet.
tonyharker
Have thanks: 7 times
Postby blackbunny » 07 Jul 2017, 05:15
The "Tube Sound Fuzz" uses a CD4049 CMOS Hex Inverter IC, which is not related to the TL071 or TL072 at all and cannot be substituted under any circumstances.
Most other Craig Anderton projects use a Raytheon RC4739 or XR4739 dual op amp IC, or a RC4136 quad op amp IC, all of which are now hard to find. These ICs have unusual pinouts, but you can substitute any common dual (4558, LM833, TL072, 5532) or quad (TL074, LF347, LM324) op amp in those circuits if you pay careful attention to the pinouts.
I built a few projects from Craig Anderton's book in the late 70's and early 80's and I still use the "Practice Playalong" and "Spluffer" sometimes.
blackbunny
Has thanked: 239 times
Have thanks: 109 times
Postby Dirk_Hendrik » 08 Jul 2017, 08:50
Sourcing electronics locally has become very hard over the last 20 years. There's too little income to be made from selling piece by piece electronics in a store.
However, since we have internet there's a multitude of options online. May I suggest Smallbear to the topicstarter since he wants to shop in the Americas.
Has thanked: 250 times
Have thanks: 995 times
Postby Ice-9 » 10 Jul 2017, 19:58
Jim9 , there are millions of them on ebay, but if you prefer Smallbear or Mouser should be able to sort you out. :thumbsup
Ice-9
Has thanked: 137 times
Have thanks: 349 times
Return to Parts Sourcing & Trading
