Looking For This Boss DC Jack
Postby eric_telemaque » 23 Nov 2017, 22:35
Hello everyone,
Long time lurker, first time poster!
It seems this time that searching here or on the Net doesn't yield results.
I lent my Boss OD-3 to a friend, only to get it back with a broken DC jack!
Thing is, this one seems to have a unusual barrel jack connector. It has 5 solder terminals with what looks like two different (+) contacts going to different parts of the pcb.
Does anyone know where I could order a replacement? I couldn't find it anywhere. Maybe I don't know where to look!
Here's pictures of hot the solder tabs are laid out on the circuit board:
Sorry, I wish I could show you the actual part, but what was remaining just self-destruct when removing it from the board...
Thanks in advance!
eric_telemaque
Re: Looking For This Boss DC Jack
Postby Rocket Roll » 23 Nov 2017, 23:25
Rocket Roll
Have thanks: 27 times
Postby eric_telemaque » 25 Nov 2017, 18:44
Yes, that's pretty much it, thanks.
Anybody ever seen this part for sale somewhere?
eric_telemaque
Postby Intripped » 26 Nov 2017, 00:19
https://www.boss.info/us/support/
Probably the best option is to ask boss directly, there's a section for parts ordering as well.
Found this also, but I'm not sure if it's the same exact part:
http://www.fullcompass.com/prod/210114-Boss-13449717
Intripped
Has thanked: 583 times
Have thanks: 215 times
Postby Ice-9 » 27 Nov 2017, 23:26
If you can't get the exact replacement part then you could always draw out the circuit around the psu section and figure out what is being switched and connected then convert it to a move available psu connecter type.
The connector Intripped linked looks good though.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Return to Parts Sourcing & Trading
