Looking For This Boss DC Jack
eric_telemaque
Post by eric_telemaque »
Hello everyone,
Long time lurker, first time poster!
It seems this time that searching here or on the Net doesn't yield results.
I lent my Boss OD-3 to a friend, only to get it back with a broken DC jack!
Thing is, this one seems to have a unusual barrel jack connector. It has 5 solder terminals with what looks like two different (+) contacts going to different parts of the pcb.
Does anyone know where I could order a replacement? I couldn't find it anywhere. Maybe I don't know where to look!
Here's pictures of hot the solder tabs are laid out on the circuit board:
Sorry, I wish I could show you the actual part, but what was remaining just self-destruct when removing it from the board...
Thanks in advance!
Rocket Roll
Has thanked: 19 times
Been thanked: 44 times
Post by Rocket Roll »
eric_telemaque
Yes, that's pretty much it, thanks.
Anybody ever seen this part for sale somewhere?
Intripped
Has thanked: 989 times
Been thanked: 305 times
Post by Intripped »
https://www.boss.info/us/support/
Probably the best option is to ask boss directly, there's a section for parts ordering as well.
Found this also, but I'm not sure if it's the same exact part:
http://www.fullcompass.com/prod/210114-Boss-13449717
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
If you can't get the exact replacement part then you could always draw out the circuit around the psu section and figure out what is being switched and connected then convert it to a move available psu connecter type.
The connector Intripped linked looks good though.
