4 wire connector
4 wire connector
Postby gkterry » 17 Dec 2017, 07:43
Anyone have a recommendation for a 4 wire connector set used to link a footswitch pcb to the main pcb? Typically I have seen one mounted on the main pcb & the other used on 4 wires coming from the footswitch pcb. Part numbers & vendor would be appreciated.
gkterry
Re: 4 wire connector
Postby phatt » 19 Dec 2017, 14:01
Welcome,
Sadly we don't use mental telepathy here so a picture of the connector in question along with a brand and model number might help you get better results. :wink:
Cheers, Phil.
phatt
Have thanks: 266 times
Postby aishabag23 » 20 Dec 2017, 16:11
gkterry wrote:Anyone have a recommendation for a 4 wire connector set used to link a footswitch pcb to the main pcb? Typically I have seen one mounted on the main pcb & the other used on 4 wires coming from the footswitch pcb. Part numbers & vendor would be appreciated.
Maybe these?
http://www.taydaelectronics.com/connect ... minal.html
Loe Sounds
aishabag23
Has thanked: 93 times
Have thanks: 11 times
Return to Parts Sourcing & Trading
