1:1 transformer (for audio isolation)
Postby snk » 11 Mar 2018, 16:33
Hello
I'm willing to build a passive audio isolation transformer to get rid of some possible hum on some FX chains.
So, i need to buy some transformers, and I am looking for a sensible balance between "sonically transparent enough" and "cheap".
I am not willing to buy expensive Jensen or Lundhall transformers : i'm looking for sub-10$ transformers.
Some Neutrik or Monacor are in the 10-15$ ballpark and well rated among users, but i am wondering if the mega cheapo chinese transformers from Ebay would be good enough for my needs ?
My questions are the following :
- how do you know the audio tech specs of a transformer (harmonic distorsion, frequency range, etc) ?
- Could you recomend any model/reference/brand of "cheap but good enough" (For instance the Bourns LM-NP-1001-B1L is very cheap, too) ?
snk
Has thanked: 35 times
Have thanks: 7 times
Re: 1:1 transformer (for audio isolation)
Postby peterc » 11 Mar 2018, 19:48
Hi SNK
The cheaper audio transformers a re generally intended for telephony useage which means a limited frequency response and low signal level handling
If you have a look at the datasheet for the above Bourns transformer
https://docs-emea.rs-online.com/webdocs ... 09a5c7.pdf
the freq response is 200Hz to 3.5 kHz which would really impinge on your signal.
Also the distortion is .1% at 0dB @1kHz, which sounds OK on paper, but as soon as you apply valve amp levels, you could be sending +10 dB or more out there. Added to the fact that the distortion down at 100Hz will be 10x worse than that at 1kHz.....
So, unfortunately you gets what you pays for. The cheaper brands to look at are OEP and Edcor (WSm and XSM ranges). In the region of $15 - $20 apiece.
The small Neutrik is very small and does not handle high levels very well, but might be worth trying.
Hope this helps
Peter
peterc
Has thanked: 41 times
Postby snk » 11 Mar 2018, 21:16
Hi, Peter,
Thank you for your reply. In the meantime, i have found the datasheet of those cheap transformers, and found that indeed, they're not suitable for "transparent' audio applications.
I think i will be buying a couple Neutrik transformers, they should be fine.
snk
Postby phatt » 14 Mar 2018, 06:31
Why not simply just break the shield on one end of interconnect cables,, ground lift.
I'd try that before messing with transformers. :thumbsup
Phil.
phatt
Have thanks: 266 times
Postby snk » 14 Mar 2018, 13:50
I never tried, i may try : how do you do ? You just take a jack plug, and unsolder the shield on one end ?
Is it safe ?
snk
Postby phatt » 15 Mar 2018, 02:37
Yes break the shield at one end of cable. That is the easy bit ,, your big problem is working out exactly what and where the hum is coming from. :scratch:
As a general rule of thumb; IF 2 audio systems are joined together and they are both grounded at the wall outlet then the shield of a mono cable can be open at one end and the signal will still pass as the units already have a ground return path.
"The idea is to not have more than one ground path".
As I have no info on your signal path or how it is powered then I can only give general advice.
The hum might be a weak psu for the pedal chain leaking onto the signal.
IF so then plug your guitar into the first pedal before amp then keep adding pedals one by one,,, Try to isolate which pedal is causing the problem.
Some pedal circuits are noise prone by nature and it takes some talent to work out how to solve these issues.
Hum can be picked up right on the pedal boards because of inductive coupling. i.e. psu cord right next to signal cord.
If the signal leads are cheap (not well shielded) then they can pick up hum.
If using switch mode psu for pedals they can cause a nightmare of interference and buzz.
Phil.
phatt
Postby snk » 15 Mar 2018, 08:22
phatt wrote:Yes break the shield at one end of cable. That is the easy bit ,, your big problem is working out exactly what and where the hum is coming from. :scratch: .
Thank you, Phil, i will try.
Ground loops/humming doesn't happen very often, so i don't need to find the source (as my effects chains change all the time, and most of the time the signal is very clean). I will try to make a custom "ground loop killer cable" ;)
But i will also make a little box with a couple transformers, as i will also use one of them as a buffer (impedance converter - of course, in that case, it wouldn't be 11).
snk
Postby roseblood11 » 15 Mar 2018, 23:14
Good transformers for high impedance signals aren't cheap. I used the Lehle LTHZ in some pedals, it's the same that is used in the Lehle P-Split II isolation box. The P-Split is always in my guitar case, every guitarist should have one...
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby snk » 16 Mar 2018, 10:10
Thank you, Roseblood;
snk
Postby Dirk_Hendrik » 20 Mar 2018, 10:06
What I found rather interesting for this application were the Wurth WE-DD inductors that were recently put to my attention:
http://katalog.we-online.de/en/pbs/WE-DD
As an example the 744878101 is quoted 2.16 eur/pc at Mouser.
Has thanked: 253 times
Have thanks: 1015 times
Postby plush » 20 Mar 2018, 10:46
Dirk_Hendrik wrote:Wurth WE-DD inductors
Using power chokes for audio isolation? :shock:
What is their frequency response?
plush
Has thanked: 24 times
Have thanks: 39 times
Postby snk » 20 Mar 2018, 16:33
Thank you Dirk for the tip (and for your great website, as well), i will consider these inductors!
snk
Postby Dirk_Hendrik » 20 Mar 2018, 18:45
Depends on the application. But in stompboxes, where we use so many parts in their non-linear region, I consider nothing sacred.
Postby plush » 28 Mar 2018, 16:32
Typical chokes have pretty low inductance, it will ruin the signal if we use low power dual inductor as a 1:1 transformer.
plush
Postby grrrunge » 29 Mar 2018, 06:01
Dirk_Hendrik wrote:What I found rather interesting for this application were the Wurth WE-DD inductors that were recently put to my attention:
With DC-resistances ranging from 0.03Ω to 1.4Ω, i guess you'll have a hard time finding a reasonably priced op amp capable of driving those ;)
They look like they're intended for use in low power flyback converters. In that case high frequency response shouldn't be a problem, but you'll quickly run into core saturation issues at low frequencies.
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby plush » 29 Mar 2018, 09:56
grrrunge wrote:With DC-resistances ranging from 0.03Ω to 1.4Ω, i guess you'll have a hard time finding a reasonably priced op amp capable of driving those ;)
Yep, I've managed to get some response from similar inductor somewhere around 1-1.5 mhz (the whole idea of me trying this was pretty retarded).
My personal verdict: unchoochable.
plush
Postby robinbowes » 06 Apr 2018, 00:52
roseblood11 wrote:Good transformers for high impedance signals aren't cheap. I used the Lehle LTHZ in some pedals, it's the same that is used in the Lehle P-Split II isolation box. The P-Split is always in my guitar case, every guitarist should have one...
[ Image ]
Any idea where to buy the LTHZ?
R.
robinbowes
Has thanked: 18 times
Have thanks: 6 times
Postby plush » 06 Apr 2018, 12:02
[ Image ]
R.
Gewgl Ebay
plush
Postby robinbowes » 06 Apr 2018, 13:51
Crikey, they're not cheap.
I was considering making a homemade Radial IC-1 ( http://www.radialeng.com/icecube.php ) but it's not worth it at that price.
R.
robinbowes
Postby mauman » 23 May 2018, 23:19
I've successfully used the Xicon 42TM018-RC transformer, which is 1:1 with 10k impedance on both sides. Data sheet: http://www.mouser.com/ds/2/449/XC-600134-1212477.pdf I got mine for less than 4 bucks each at Mouser. The data sheet says the 3dB frequency response is 300Hz to 3.4kHz, but don't be afraid of that - after adding enough gain to bring it back it unity, my application measured quite flat to 10kHz. I got the idea from this circuit: http://www.geofex.com/FX_images/TransformerSplitter.pdf , you could adapt it from a splitter to a single in/out for isolation. Regards, Mike
mauman
Next
Return to Parts Sourcing & Trading
cron
