Systech - Harmonic Energizer
Re: Systech - Harmonic Energizer
Postby D-Day » 09 Nov 2011, 00:14
Just finished building one on a Madbean 'Karate Shop' PCB. Added a volume control and the suggested by Grizzlydude 1.5u output cap on a switch with the other option being stock. Fun build, nice sound. I built it for an owner of an original so here in a few I get to see how he thinks it stacks up. Can't do a side by side as the original unit is now busted but the owner is a dog eared engineer who used it for lots of rock sessions over the past 20 years.
D-Day
Mojo Book Buster
Has thanked: 109 times
Have thanks: 23 times
Postby D-Day » 09 Nov 2011, 18:45
Works like a charm! My buddy says it doesn't sound quite exactly the same but it definitely does the same job and he's just tickled pink. We hooked it up to a red knob Fender Concert and I noodled on my SG while he twiddled knobs. This thing is fun and awesome by itself but get a fuzz or a distortion in front of it and let the games begin! Thanks to Joe, Grizzly, Madbean and anybody else that contributed to my ability to give this gift to one of my greatest friends ever.
D-Day
Mojo Book Buster
Postby terrapin » 14 Oct 2012, 01:56
Almost a year on and PurplePeopleEater's pcb layout (and Joe's original gut shots) have long gone. Anyone still have them and care to repost them? Pretty please?
terrapin
Postby JOHNO » 02 Jan 2013, 09:12
For this message the author JOHNO has received thanks: 3
Nocentelli (02 Jan 2013, 09:42), pinkjimiphoton (06 Jan 2013, 02:22), terrapin (16 Feb 2013, 01:39)
JOHNO
Has thanked: 52 times
Have thanks: 62 times
Postby jreeves47 » 19 Jul 2013, 05:04
Some guts
jreeves47
Has thanked: 41 times
Have thanks: 20 times
Postby Nocentelli » 06 Aug 2013, 14:00
Got this on the breadboard at the moment, sounds good. I used a 2N5457 for the input buffer which works fine, and didn't bother with any of the power related circuitry other than the 10k/10k/10uF volateg divider.
I've also got a switch that puts either one or two pairs of antiparallel 1N4148s across the output opamp's inverting input and output, which makes the higher gain settings a bit smoother: The single pair just clips a bit earlier than two pairs. I'll probably use this when I box it up.
I have one question for anyone who understands this circuit: I'd like to use my EV-5 expression pedal for the frequency pot. It's a 10k, and I'm not at all sure what I'm doing, so I just tried reducing the 20k resistor that leads to the freq control opamp by a factor of 5 to match the pot value decrease. However, I just get squeals (through headphones - ouch). I'll have a go at altering those two 10uF caps, but I'm not sure if they should go up or down in value. Any ideas?
Nocentelli
Has thanked: 878 times
Have thanks: 844 times
Postby Mbas974 » 06 Aug 2013, 16:49
Are you using RnFR (page 5) schematic ?
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby Nocentelli » 06 Aug 2013, 18:52
Yep
Nocentelli
Postby grizzlytone » 23 Aug 2013, 20:24
Nocentelli wrote:Got this on the breadboard at the moment, sounds good. I used a 2N5457 for the input buffer which works fine, and didn't bother with any of the power related circuitry other than the 10k/10k/10uF volateg divider.
Try increasing those 10uF caps with a factor of 5 (47uF), it might just work...
/MB
For this message the author grizzlytone has received thanks:
Nocentelli (23 Aug 2013, 20:56)
grizzlytone
Has thanked: 27 times
Have thanks: 75 times
Re: Systech Harmonic Energizer — any interest?
Postby aishabag23 » 08 Oct 2016, 05:03
PurplePeopleEater wrote:
PurplePeopleEater wrote:Here's a PCB layout for the Harmonic Energizer. You can board mount the pots or run wires, whichever. The PCB size is 3 inches x 1 3/4 inches, so it will easily fit in a Hammond 1590BB sized enclosure. I used a TL074 (as in Grizz' vero layout) instead of using 2 TL022 op amps. It just keeps things neater and the sound difference should be marginal at most. It should be correct (Eagle checks connections), but if you see any errors, please let me know.
I forgot to show the board connections on the bottom of the layout. The layout attached below has them marked.
Greetings,
Any chance you could link me to this? I can't seem to open the attachment (says it no longer exists).
Thank you!
Aisha
Loe Sounds
aishabag23
Has thanked: 95 times
Have thanks: 11 times
Postby roseblood11 » 05 Sep 2018, 14:57
Does anybody know, how the additional switches in this version work? Would be great to include them.
https://youtu.be/lhNFPsbv2Lk
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby Lani » 11 Oct 2018, 04:57
Thought I would add my layout here as well... Not verified yet but will build it in the next couple of days and let folks know. :thumbsup
Lani
Postby cniers13 » 16 Nov 2018, 17:57
Lani, have you gotten it to work? I'm curious because I like the idea of adding a volume knob, instead of just the three knobs.
cniers13
