SolaSound - Tone Bender MK1.5 [schematic]
- jalmonsalmon
AH yeah! Changing the grid did the trick!
thanks! hehee
I like that DIY software... Next goal for me, to do a layout from scratch of anything just so I get the jist of it
thanks! hehee
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
You can do everything with DIYLC mate, your creativity is your limit. I did hell of the layouts, tagboards, vero, pcb for amps and effects. Small and big ones. Check out my website, all was done with DIYLC
- jalmonsalmon
I have only used this for the first time yesterday and yeah I also noticed you can layout guitar wiring too... Be great for a JTM45 build... How do you get it to save as PDF and have the image BIG lol or default to approx 200% zoom?sinner wrote:You can do everything with DIYLC mate, your creativity is your limit. I did hell of the layouts, tagboards, vero, pcb for amps and effects. Small and big ones. Check out my website, all was done with DIYLC
Your work Sinner on your site is impeccable! Or close to it hehehe~!
- sinner
Click file (left upper corner) -> Export to PDF, or Expoer to PNGjalmonsalmon wrote:How do you get it to save as PDF and have the image BIG lol or default to approx 200% zoom?
I was going to do an tutorial of DIYLC (at least my way for it), with my set of templates, and few ideas to simplify the process, but I always find myself busy with something else... I will one day. I use DIYLC for almost everything, including chassis plan draws
I'm a vintage crap whore, and I doing my bestjalmonsalmon wrote:Your work Sinner on your site is impeccable! Or close to it hehehe~!
- jalmonsalmon
You and me both! Everything I use is vintage based or actual vintagesinner wrote: I'm a vintage crap whore, and I doing my best
- beedotman
It's all wrong - why did You replaced 47K with 100K and 100K with 47K? Copper MK1.5 follows classic MK1.5 schematic but with added pulldown capacitor on input to ground and additiona 47K resistor on Q1 base to ground.jalmonsalmon wrote:Hey all, I put together something real quick that may work. Needs to be verified and I do not have all the parts to mess with this yet.
It is loosely based on that copper top Mk 1.5 with a bias pot and will work with your neg ground power - borrowed from a layout that IVIark did for a fuzz face but I changed the passive values
so it works for the tonebender mk1.5, or should LOL
If anyone that is in the know can sort of check this over for errors, for this is the 1st time I ever tossed a vero together.
[ Image ]
- beedotman
- jalmonsalmon
Yeah I was looking at the layout vs schematic all wrong.
I see where to add the two passives by looking at the Tonebender MK 1.5 layout on your turrotboard.org site since it is more or less identical to the coppertop.
When I get a chance I will put another layout based on the turrotboard.org one I see. I am just trying to understand how to get from a schematic to a layout, arranging everything on the stripboard is still a challenge to me.
I am only good at making pedals from a layout LOL - Still trying to figure out how to make my own from a schematic... Fun sTUFF though!
And I cannot wait to make one of these. I take it, I can use just about any transistors since I cannot find a pair of OC75s that work...
CHEERS!
CHEERS!
- beedotman
- jalmonsalmon
Moderator, delete that other layout I did! All wrong.
This one should be good as well with the neg power converter - Added 47k resistor were Arcol's measured at 43k
If this one is wrong I give up... And will hit the layout 101 books again
Finished mine yesterday with an AC128 in q1 and an OC75 for q2, sounds really good and biases up fine with the stock resistors. Like a low gain MKII on some settings with a more gradual cleanup than a FF. For me, it actually works better for early Zeppelin tones than a MKII
- beedotman
what gains did you used and what is Q2 colector voltage?DonDougie wrote:Finished mine yesterday with an AC128 in q1 and an OC75 for q2, sounds really good and biases up fine with the stock resistors. Like a low gain MKII on some settings with a more gradual cleanup than a FF. For me, it actually works better for early Zeppelin tones than a MKII
Q1 is 69 hfe and q2 is 107, leakage for both around 100uA. I tried biasing q2 with a trimpot, and liked it best at around 5,5V, which happened to be around 8k I went through lots of gain configurations and q2 voltages (started at the usual 4,5-5V), and liked this one best because it gives a nice overdrive sound with the guitar volume backed up, has a good amount of gain and doesn't get mushy even with the attack pot fully open.beedotman wrote:what gains did you used and what is Q2 colector voltage?
- jalmonsalmon
I have a couple of OC75s I can try but I think they are too leaky.
I have one that is about 67 hFE @ .255, another is 85 hFE @ .275 and another that is 108 hFE @ .441!
they work ok for a Mk II but I suspect if I try them in a MK1.5 they will not bias. I need to try and find some better OC75s.
Anyone know if you can use OC140's? I know to reverse all the polarity since they are NPN but not sure if those would be good for a MK1.5
- phibes
Your OC75's should work fine in a 1.5 is they work in a MKII. The gains are right and the leakage ain't 'too bad'. To adjust bias, drop the 47K on Q1's collector for a 100K trimmer.
Ken
Ken
While swapping transistors around I've found that, while they bias up fine with a little tweaking, leaky ones (over, let's say, 100uA) didn't sound as smooth as low leakage ones with the same gains. The sound got kind of harsh and sputtery (not the decay, that was fine), a bit like a Fuzzrite. Still very usable, though; and after all, it's still all a matter of taste! Try the ones you have and if you like them, don't worry about it too much
- Electric Warrior
100µA is very low leakage for an OC75. Most leak a lot more.DonDougie wrote:While swapping transistors around I've found that, while they bias up fine with a little tweaking, leaky ones (over, let's say, 100uA) didn't sound as smooth as low leakage ones with the same gains. The sound got kind of harsh and sputtery (not the decay, that was fine), a bit like a Fuzzrite. Still very usable, though; and after all, it's still all a matter of taste! Try the ones you have and if you like them, don't worry about it too much
- phibes
EW's right. Even 200-300uA for leakage ain't bad on those. Those shouldn't spit nearly as much a Fuzzrite. Were you tweaking the bias on Q1 or Q2?
Ken
Ken
- Electric Warrior
Some of them do have a sweet kind of nastyness going on, though.
