Wilsic Sound - Wah Wah.
Postby kaycee » 09 Aug 2010, 11:29
The build instructions for the Wilsic Sound Wah Wah kit.
Note that in the schematic above this is a PNP positive ground device. The original transistors were silicon devices, I think that I have sourced some from somewhere and they are nothing particularly special. Below is my stripboard layout for the Wah which I have converted to NPN - negative ground. Usual suspects work in this: BC108, 2N3904 etc. The original layout is smaller, but the parts are all over the place, I've built working devices from my layout. Substitute the old values with nearest value you can find and it should be fine. Black squares equal track cuts.
For this message the author kaycee has received thanks:
sinner (26 Nov 2011, 13:32)
kaycee
Has thanked: 31 times
Have thanks: 13 times
Re: Wilsic Sound Wah Wah.
Postby jrod » 09 Aug 2010, 14:39
Right on, kaycee! Thanks! :thumbsup
Looks like the original transistors have an E-C-B pinout.
jrod
Has thanked: 326 times
Have thanks: 41 times
Postby Chugs » 10 Aug 2010, 08:44
What does it sound like compared to a typical Vox or Crybaby?
Chugs
Has thanked: 59 times
Have thanks: 48 times
Postby mictester » 10 Aug 2010, 11:24
Chugs wrote:What does it sound like compared to a typical Vox or Crybaby?
It's nothing like them - it's a sound of its own. It has a low pass characteristic, with a peak just below cut-off. It actually sounds really good, and costs almost nothing to try out! Give it a try.
A quick vero layout I found in one of my old old notebooks here:
The only changes I made were to add a 470 ohm resistor in the battery +ve leak, and a 100uF 16V electrolytic across the supply
rails. I used the usual "true bypass" DPDT with LED indicator circuit.
For this message the author mictester has received thanks:
sinner (26 Nov 2011, 15:02)
mictester
Has thanked: 32 times
Have thanks: 795 times
Postby kaycee » 11 Aug 2010, 13:23
I ended up with BC108's in mine I think? Still not boxed up yet, thinking about adding the Foxxrox's wah buffer to it. Soundwise its similar to the Colorsound inductorless wahs.
Mictester, you mention a 470 ohm in your text, but I don't see it on the layout?
kaycee
Postby mictester » 11 Aug 2010, 13:32
kaycee wrote:I ended up with BC108's in mine I think? Still not boxed up yet, thinking about adding the Foxxrox's wah buffer to it. Soundwise its similar to the Colorsound inductorless wahs.
I missed it off that diagram! Sorry :( Just add a 470 ohm between the PCB and the Battery +. With the extra 100µF across the rails, it helps a lot. I also added the usual 1N4001 "idiot diode", reverse biased across the supply rails to prevent damage in the event of the wrong polarity adaptor being plugged in. I used a 1/8th Watt 470 ohm resistor, which would vapourise if the "idiot diode" conducted!
Corrected diagram (I missed one link and the 470 ohm resistor):
This circuit is worth experimenting with - you can "tune" the range of frequencies covered, and alter the shape of the resonant peak. I'll leave these modifications for the class to work out for themselves.....! :)
mictester
Postby jrod » 11 Aug 2010, 14:25
Are the caps connected to the 10K pot wiper 0.01uF?
jrod
Postby mictester » 11 Aug 2010, 15:38
jrod wrote:Are the caps connected to the 10K pot wiper 0.01uF?
Yes. 1000 nF = 1µF and 1000pF = 1 nF It's what we use over here in Europe. So (for example) 470 nF = 0.47 µF and 10 nF = 0.01 µF
We also tend to put the multiplier letter in place of the decimal point (little dots are easy to miss) - like this:
4700 ohms = 4.7 kohms - we'd write 4k7 and 0.0047 µF would be written 4n7.
mictester
Postby jrod » 11 Aug 2010, 16:39
Thanks, mictester.
jrod
Postby Zombie_Crush » 22 Nov 2011, 15:55
Hi Mictester
Doe the additional 100uf go from D14 to E14? Or is that simply another jumper.
Also will the 470k resistor be needed if i am running from a 9V power supply.
Cheers :)
Zombie_Crush
Has thanked: 30 times
Re: Wilsic Sound - Wah Wah.
Postby mictester » 22 Nov 2011, 16:49
The 100uF capacitor is C8 on the layout, and D14 - E14 is just a jumper.
The extra resistor is 470 ohms (NOT 470k!!). It reduces the current consumprtion of the circuit a little, but more importantly, it cleans up the +9V supply rail. It makes the circuit less susceptible to hum and lowers the noise a little.
mictester
Postby Zombie_Crush » 22 Nov 2011, 17:49
right i see now, and apologies I meant a 470R
oh! btw - what wiring did you use for your true bypass DPDT and LED circuit.
Shall try this circuit out
Zombie_Crush
Postby Bernardduur » 22 Nov 2011, 19:26
Nice such an inductorless wah pedal.......
I am quite happy with my Parapedal clone...... but I always like these ideas.....
Bernardduur
Has thanked: 87 times
Have thanks: 483 times
Postby mictester » 26 Nov 2011, 12:27
Zombie_Crush wrote:right i see now, and apologies I meant a 470R
I didn't ever bother with an LED (you can work that out for yourself - just use a TPDT switch!
Here's a rough wiring diagram for what I did:
mictester
Postby sinner » 26 Nov 2011, 13:53
Schemo redraw, the one provided causes to blindness
I hope I didn't fuck up anything
Has thanked: 1240 times
Have thanks: 1099 times
Postby sinner » 26 Nov 2011, 15:01
And matched to the real one [PNP] - vero layout
For this message the author sinner has received thanks: 2
kaycee (26 Nov 2011, 18:37), PEPPER! (06 Nov 2014, 02:33)
Postby sinner » 26 Nov 2011, 15:19
And NPN version. BC183L have the same pin-out and orientation just like the original PNP transistors
Zombie_Crush (13 Feb 2012, 17:00)
Postby kaycee » 26 Nov 2011, 18:41
sinner wrote:Schemo redraw, the one provided causes to blindness
Looks right to me - nice layouts, thanks!
kaycee
Postby sinner » 26 Nov 2011, 19:12
It's not mine ;) It's Wilsic's layout. Want to see mine? I bet I can better than this...
Thanks for the confirmation, and thanks for project data. I'm kinda dig this project... I'm hot to check how it sound :!:
Postby mictester » 26 Nov 2011, 22:45
I just built one of these earlier today. The Vero layout is a bit different because it's got a Fuzz on the same board (it's a Fuzz-Wah for a friend), and it sounds great. Unfortunately, I've just broken the pedal mechanism, and I've got to go to work in 15 minutes, so it'll have to wait until tomorrow to get the mechanism mended and the thing fully tested.
I'll draw up a neatened version of the Vero tomorrow, and post it here.
mictester
Next
Users browsing this forum: No registered users and 8 guests
